Small Form Factor SN95G5V3 vs SN95G5
Discussion in 'Hardware' started by invalid, 2 Jun 2005.
  1. invalid
    invalid What's a Dremel?
    23 Jan 2005
    What is the difference other than one being newer?
    SN95G5V3 vs SN95G5?
  2. DickH
    DickH What's a Dremel?
    6 Jun 2004
    support for newer cores like venice, and I believe the v3 has the hardware firewall.
  3. invalid
    23 Jan 2005
    Why then, is the v3 cheaper everywhere? If it has more core support and such? Just trying to figure this out
    Thanks
  4. Darkedge
    Darkedge Minimodder
    26 Nov 2004
    as afr as i can tell get the newer version - I have a v1 and it's being an utter utter BITCH.
  5. invalid
    23 Jan 2005
    How so Dark?
  6. blackadder1000
    blackadder1000 What's a Dremel?
    23 Mar 2005
    Does anyone know when they are coming out in the UK and how much they will cost?
  7. invalid
    23 Jan 2005
    Just got mine today and lovin it so far. VERY fast to setup too.
  8. Darkedge
    Darkedge Minimodder
    26 Nov 2004
    the front ports don't work, the SATA interface will not boot and if I place two 512 mb sticks of ram in the machine I get no post nothing just fans running at max.
    Ontop of that weirdly changing any piece of hardware, for example swapping DVD drives requires the mains plug to be disconnected afterwards - or No boot/post.
    Have a search online and you'll find that the v1 have had alot of returns and replacements which I believe the v3 has fixed, white adding more core support and several other things too.
    Good kit - just variable.
  9. blackadder1000
    23 Mar 2005
    The SN95G5 v3 will support the new AMD dual core chips. Shuttle said they will release an update for it very soon. Linky
  10. Charles_London
    Charles_London What's a Dremel?
    6 Jan 2006
    SN95G5
    The difference is that the V3 has a hardware update.
    The main difference is CPU support. The V2 does not
    support E-Stepping.
    V3 is compatible with the new E-Stepping CPU's (including x2 Dual core) and V2 does not!
    Hope this helps you. :D
    kind regards
    Charles_London :thumb:
  11. fev
    fev Industry Fallout
    13 Aug 2003
    v1.3 supports dual core....
    complaints about ram are becuase the user is generally using poor quality ram..
    the V3 hardware firewall is crap and can cause bluescreens...
    just thought i'd clear up somethings there
