CPU So I bought a 1366 Xeon. **6 Cores Of Fun**
Discussion in 'Hardware' started by Pookie, 8 Aug 2014.
  1. Pookie
    Pookie So this is permanence, love's shattered pride.
    4 May 2010
    I think that was the norm for Gigabyte X58 boards. Mine would easily get that toasty without decent airflow.
  2. johnim40
    johnim40 Well-Known Member
    23 Apr 2009
    The mobo is on a piece of wood at the moment so it should be ok when I put it in my 750d then the h100 and some sp120s will be blowing over it :)
    What temps program are you using for the xeon
  3. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
    Hey folks, i am rather tempted by this (although i dont really need it) and i was wondering who you guys bought yours from?
  4. johnim40
    23 Apr 2009
    Post 114 mate
    I have had mine upto 4ghz too
    What rev is your mobo
    slaw likes this.
  5. slaw
    13 Feb 2003
    thanks
  6. johnim40
    23 Apr 2009
    rebuilt my second machine today now using a x5650 hexcore from a i5 3570k which will go in a itx board
    X5650
    24gb corsair xms3
    1 evga 660s
    2 1tb wd red
    2 2tb wd red
    Ocz 120gb ssd
    1 750gb wd black
    Corsiar 750d case
    Corsair cx750 psu
    Corsiar h100
    Pioneer bdxl bluray writer
    Connected to a samsung s24c450 monitor
  7. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Sorry for the late reply - I decided to spend the extra £5 and get mine from a seller with 100% feedback. CPU works a treat, been running it 4.3GHz daily now for weeks on end. Will probably take it back down to 4.2GHz when I reinstall Windows.
  8. mrbungle
    20 Sep 2004
    Ive got a new 1366 board to add to my hoard :D
    May need another hex to stick in it :p
  9. nimbu
    nimbu Well-Known Member
    28 Nov 2002
    Nice. Still need to do my rebuild, at which point I can start playing with clocks!
  10. mrbungle
    20 Sep 2004
    Did you keep your gene?
  11. nimbu
    28 Nov 2002
    Much to the disappointment to everyone that had subscribed to my price check thread yes I did!
    Have it all running at the moment and appears to be working fine.
    Rig atm is:
    X5650
    Gene
    Prodigy M
    H100i
    7870TE
    12GB Ram (3x 4GB)
    2 x SSD
    Antec Semi modular PSU
    Hoping to move over to:
    X5650
    Gene
    Prodigy M
    H100i
    GTX 750Ti (Considering a 970 or holding out till the 960 is out)
    24 GB Ram (6x 4GB)
    2 x SSD
    Silverstone fully modular SFX psu.
    Having the extra horse power when I am in and out of VMplayer is great! My gaming needs arnt huge atm (Wow and Eve) hence the down shift to the 750.
  12. nimbu
    28 Nov 2002
    Which reminds me, I just ordered the additional memory as it was on scans today only!
  13. mrbungle
    20 Sep 2004
    lol and im still finding 6GB enough ;D
  14. johnim40
    23 Apr 2009
    I have a supermicro board now thanks to mr bungle looking on ebay but need to wait for a pcie extender as the 16x and 8x inline so a normal card wont fit without the extender
  15. mrbungle
    20 Sep 2004
    Bugger sorry didn't twig that that would clash!
    Plenty of space for an extender though.
  16. nimbu
    28 Nov 2002
    Do tell what board you have!
  17. LennyRhys
    LennyRhys Oink!
    16 May 2011
    I was until I started editing videos... now my RAM usage jumps to over 5GB when I start very simple editing in After Effects. I'm going to need to consider going to 12GB or 24GB which in turn will affect what OC I can run, but for tasks like video editing, quantity is definitely more important than speed.
  18. Pookie
    4 May 2010
    I think 12GB in triple channel is plenty for gaming, and even most video/photo work (unless your a pro). Will having all six slots populated have an effect on a decent overclock?
  19. johnim40
    23 Apr 2009
  20. Big Elf
    23 Apr 2009
    I've had all 6 RAM slots populated on 3 different X58 boards with an i7 970 and 990X. I had to increase the VTT/QPI voltage a tiny amount with the 970 and 6 slots populated compared to just 3 slots but the 990X runs 24GB (6 x 4GB) at 2000MHz with a QPI voltage of just over 1.23v with an overclock of 4.7GHz.
