Graphics so i just bricked my hd5850..
Discussion in 'Hardware' started by jakobfrimmel, 1 May 2012.
  1. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    so yea I was flashing the bios on my powercolor hd 5850 and I must have done something wrong somewhere... cause I basically just bricked my 2 year old hd 5850 :?
    1. If there are any suggestions on how I could fix this problem... please help …
    2. I will be going out this weekend to get myself a new card... the problem however is that I do not want to spend a lot as im building a complete new system this summer.. therefore id need any suggestions on cards that are similar power
    I live in Shanghai and im willing to spend up to 1000RMB...
    oh and I basically need something where I can do light gameing and will last me till this summer
    any suggestions would be greatly appreciated :)
  2. PocketDemon
    PocketDemon What's a Dremel?
    3 Jul 2010
    if you can memorise (or write down) the key strokes needed to run the flashing program (made simpler if you shorten the file name to a single character), you can try reflashing it 'blind' - ie giving it enough time to get to the command prompt &, after typing, leaving it for a couple of minutes to ensure that enough time's passed.
    &, naturally, if you can get hold of the original f/w this increases the chances of sorting it out.
    Simply that i had to do this once on with an almost new 4870x2 (back in the day when it was a top end card & cost stupid amounts) after an alt f/w 'bricked' the card, & reflashing with the original f/w sorted it out - & it's still working now.
  3. jakobfrimmel
    2 Jan 2011
    okay ill give that a shot... but everything was going fine and I did it before so I wasn't prepared to bricking my card.. so I don't really remember exactly where and what all the programs where called... so basically I got cocky with my flashing skills :(
    but ill give it a shot!
    thanks for the advice!
  4. jakobfrimmel
    2 Jan 2011
    SO I took the card apart... and I noticed that where the heat pipes joined with the fins there was a slight yellowish residue...…
    When removing the heat sink completely the thermal paste was applied so thickly that a large amount was just sticking around the actual gpu socket....
    im actually quiet shocked at the lack of quality.... powercolor.. im looking at chu!
  5. mrbungle
    20 Sep 2004
    You have onboard graphics
    Use that while flashing the card...
  6. jakobfrimmel
    2 Jan 2011
    I dont… :p JAHAHA
    I just noticed ive had the wrong motherboard in my signature the whole time!!
  7. mrbungle
    20 Sep 2004
    Well alternative is to pick up a cheap pci-e card then you dont have to flash blind.
    Should be easy to undo.
    jakobfrimmel likes this.
  8. jakobfrimmel
    2 Jan 2011
    Ah I hadn't thought of that! thanks :)
    But ive anyway got to revise for my IB exams so maybe this was gods cruel way of telling me I need to revise but thanks for the help!!
  9. Bede
    Bede Minimodder
    30 Sep 2007
    RMA it, tell them that their shitty over-application of TIM bricked your card (which it probably did).
  10. jakobfrimmel
    2 Jan 2011
    hmmmm I might just do that!!
    the problem is my dad threw out the original box when we moved a year ago :/
    but ill see what I can do!!
    thanks
  11. Dreamslacker
    Dreamslacker Minimodder
    13 Sep 2006
    I used to use a PCI graphics card (you should be able to get one for cheap) for flashing the firmware (firmware set overclocking via SGI Quadro firmware) on my old Geforce 256 (hard modded to Quadro).
    You can do the same but you might need to boot into the BIOS with only the PCI card attached and set VGA first on PCI slot.
  12. jakobfrimmel
    2 Jan 2011
    ill give that a shot :) thanks for the help!!
  13. jakobfrimmel
    2 Jan 2011
    oh and does anybody know if theres a step by step guide how I do this? as I don't want to mess everything up again!
  14. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
