Modding So I tried my hand at the Dremel
Discussion in 'Modding' started by fieroloki, 25 Mar 2005.
  1. fieroloki
    fieroloki What's a Dremel?
    3 Jan 2004
    Old case top that was collecting dust... Still need to clean up the edges as I JUST got done with the cuts.....Please note this is the FIRST time I have tried something like this. But I think for the design I want on my next case ill find someone with a waterjet. :D
  2. Etacovda
    Etacovda What's a Dremel?
    4 Nov 2003
    Very clean, well done.
  3. dharma punk
    dharma punk What's a Dremel?
    7 Nov 2004
    Those are some very nice cuts. Much better than my first ones. I had fan holes that looked like eggs. :duh:
  4. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    I still have fan holes that look like eggs, and I've been using a Dremel for years...:worried:
    Nice job. Clean cuts with a Dremel are an art in themself :hehe:
  5. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    i wish that my first job looked like that, mine looked really really bad, but i was amazed at my first try using aluminium and a router, that came up really good, ill post pics when i find them
  6. imgregrice
    imgregrice What's a Dremel?
    16 Mar 2005
    :thumb: looks very nice I need to play around with my :dremel: more.. you did a good job.
    btw I love that mesh where can one get some? I think it would work well with my current project.
    link in sig
    thanks and mod on bro :rock:
  7. m0ng0lh0rde
    m0ng0lh0rde What's a Dremel?
    5 Jun 2004
    At a guess, I don't think it's mesh. It looks like the plastic diffuser stuff on flourescent light fixtures like in an office. Probably about $5 for a 2x3 piece or so.
    Am I right? Do I win a cookie?
  8. fieroloki
    3 Jan 2004
    Your right, but no cookie sorry. I ate them all. :(
  9. tater salad
    tater salad What's a Dremel?
    26 Nov 2004
    lol, looks good.
  10. pr0xZen
    pr0xZen What's a Dremel?
    5 Nov 2004
    Nice work :) I also like the personality of your touch to this. It's pretty similar to my own work, although I yousually prefer a bit more harp edges. But thats just me. Keep up the good work, I see talent and potential.
  11. Visionism
    Visionism What's a Dremel?
    24 Mar 2005
    Very nice job on the cutting. Glad to see you changed your mind from the biohazard thing. Im assuming the next job is redoing the paint? :thumb:
  12. fieroloki
    3 Jan 2004
    This isnt going on a case I will use. This is just practicing my Dremel skills. The design I want is this.....But dont think im skilled enough yet.
  13. Visionism
    24 Mar 2005
    I dunno about that. More complex patterns aren't really that much harder once you have the essential techniques down. They just take more time and care. Go slow and I'm sure you'll do fine.
  14. JoyRider
    JoyRider What's a Dremel?
    7 Jun 2004
    Just like he said. I did my dragon sidepanel at the first time, it took me 6 hours straight to do it so yeh. It isn't that much harder, just be patienced and think about every small cut, how to cut it best. :D
  15. pcjabber
    pcjabber What's a Dremel?
    24 May 2003
    Looks good :dremel:
    Did you cut that from the painted side or the non-painted (inside) side?
    If from the painted side (that's kinda what it looks like), I would suggest cutting from the INSIDE next time. It conceals it if you slip, and it also keeps the painted edges there, vs having the little silver streaks on the edges =).
    Also, I would advise sanding it down a bit (doesn't looks smooth enough on the edges.) you don't want to slide your finger along it without it being nice and smooth... :eeek: :wallbash:
  16. fieroloki
    3 Jan 2004
    Well as was said at the top, this was practice on a non-used case and that the cuts were just finished. So yes, if I was to use it there would be alot of clean up to do. This was just the first time trying this and wanted to see how I could do it. :)
  17. mrpete
    mrpete What's a Dremel?
    8 May 2004
    V good for a first time
  18. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    Great 1st go, i would thought try and have a go at that design with a jigsaw then do the smaller bits with the dremel. then u wont spend as much time putting new discs on.
    mod on and get spinning :dremel:
  19. fieroloki
    3 Jan 2004
    Only used 1 disk...Was a reinforced high dollar one, but only used one. :)
  20. dastt
    dastt What's a Dremel?
    23 Apr 2004
    wow nice first job and at only 1 disk, nice. just get out the files and emery cloth and within no time those cuts will look perfect.
