Cases So im building a Thermal Reactor :P
Discussion in 'Hardware' started by Undercloacker, 12 Jan 2009.
  1. Undercloacker
    Undercloacker AirFlow
    8 Jan 2009
    ok people here is the deal
    im building a computer that is gonna run very hot, planning on OCing and everything
    in short, the specs are
    i7 920 with a v8 cooler from Cooler Master
    2x280 supercloacked
    6gb dominator and 3HDDs
    we all know GPUs and CPUs run very hot
    so here is my question
    i have an 830 stacker from Cooler MAster
    and bought 4 120mm fans
    I wanted to know having in mind my previous specs
    which fan distribution would u guyz use
    what i did was the following , u tell me what u think
    i got the 130mm fan from the PSU blowing out
    3x120mm on the side door, blowing out (2 in the GPUs and 1 in the memories)
    + the 120mm fan under the PSU blowing out
    and i got the HDD rack fan blowing in
    and an upper 120mm fan blowing in
    Low Preassure Cheesecake :p
    now u guy tell me if my distribution is fine or would u change anything
  2. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    I wouldn't personally have a fan at the top as an intake, heat rises so why push against it?
    notatoad likes this.
  3. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    Seconded. I'm fairly sure that ordinarily, fans on the back and top are exhaust fans, and fans on the left side and front are intake fans.
    If you happen to have a fan on the right hand side I suppose that would be exhaust too, but I've only seen one case with a fan there (the Thermaltake Spedo IIRC).
    Another good clue is any part of the case with a dust filter is likely used for intake of air.
    You're looking for good quick throughflow, to keep the air moving through the case, to keep temps down best.
  4. Undercloacker
    8 Jan 2009
    havent really thought of that but u certainly right, so the upper is going to be an outtake,
    and the one which was blowing out where the ram is, now is gonna be an intake, and i belive ill have a nice flow there
    any other suggestions?
  5. Diosjenin
    Diosjenin Thinker, Tweaker, Et Cetera
    14 Jul 2008
    The fans on the side should all be intake or all be exhaust. One thing you don't want is to have something of a loop created where one fan just exhausts most of the air that the fan right next to it just pushed in and visa versa.
    If I were you, I'd make your side and front fans intake, and your top, rear, and bottom fans exhaust. It's positive pressure, sure, but that can be good for dust management (dust is theoretically forced out of the case instead of drawn into it in a negative pressure configuration). Think of it as one giant top-down cooler over your entire motherboard.
    - Diosjenin -
  6. wyx087
    15 Aug 2007
    personally (Antec P182 user) i would seal the side ports, as those will just create turbulence. just intake at front, output at back and top.
    well, at least that's the concept of P182, and it works great.
  7. Undercloacker
    8 Jan 2009
    the intake in the side would be a mistake, for sure, it would just cause chaos on my air-flow
    im just gonna create low preassure inside, and the air is gonna push in from the back of the mobo, and from right under the case
    so its gonna be 3 exhausts in the side
    wuyanxu, cm 830 stacker is quite hard to seal, since its open fromealmost everywhere the best option is to use these racks to let air flow in by itself as i been told
  8. Jipa
    5 Feb 2004
    The problem with "negative pressure" fan placement is that in practice that means that all the holes in the case are pulling in DUST. Lots and lots of it. So if there just are enough filtered fan holes in the case (I have no idea tbh what case that is) I'd use them and see if it's enough...
  9. Undercloacker
    8 Jan 2009
    this is my case
    looks smthing similar :p
    and closed up its like this :p
    anyway hehe
    im gpoing for negative pressure, but ill need dust filters,
    good thing i dont live in a dusty place
  10. pimonserry
    20 Dec 2008
    You say that, but there's always more dust than you think.
    Also, see here for home-made dust filters. Or you could buy some proper ones, here or here.
    IMO the first proper one (chilledpc.co.uk) looks the best.
  11. Undercloacker
    8 Jan 2009
    ty on dust tips :) got that covered i think,
    i work at a computer manufacturer and got some black dust filters for my vents hehe
  12. GavX
    GavX What's a Dremel?
    5 Apr 2008
    I would go with more fans, keep the ones on the side, because if you just rely on the intake at the front and the exhausts at the rear and top, there will probably be a fair bit of stagnant air near the GPUs, you payed for the fans, I say use em! That is going to be a toasty rig! Also regarding airflow pimonserry, it can go whereever you want it to, as long as you plan it, for example my latest case is going to have rear and front as intakes but an equal number of fans in the foor as exhausts, same with my TJ07, 2 intakes at the rear blowing forward, and roof exhausts. I think it is a better idea as it means the immediately how components like CPU, MOSFET get a good dose of fresh air rather than relying on the front intake to get there, pass other hot components before being expelled, just my 2pence though
