Storage So WD my cloud external drives have WD Reds in?
Discussion in 'Hardware' started by neocleous, 10 May 2016.
  1. neocleous
    neocleous Minimodder
    12 Feb 2002
    Hi all,
    As the title are there Red drives in the my cloud external drives? Also do you get any warranty if you remove it from the chassis?
    Thanks
  2. Mister_Tad
    27 Dec 2002
    A few reviews seem to suggest that they're reds, but there's no warranty for the standalone drive once it's removed in theory. In practice, the only way you can know is to whip it out and check the SN
  3. phuzz
    phuzz This is a title
    28 May 2004
    Can you do SMART over USB? You might be able to get the serial that way.
  4. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    No WD myCloud internal drives are only warranted when left in the original enclosure (with all warranty seals intact naturally). It just tells you it's an OEM drive.
    Or at least that's what happened when I stripped some down at work.
  5. Gareth Halfacree
    4 Dec 2007
    You can on Linux; don't know about any other OS.
