Well, I need to cool my hard-core K6 lll thats running @ 550 Mhz. Sadly it is harder than you think to find a nice, inexpensive socket 7 cooling solution. No I am not looking for a water cooling setup, I am just looking for something that can push alot of air (noise is not a problem) and keep my system cool
Depending on the space around the socket - a socket A or socket 370 cooler might fit (If I recall correctly the clip is the same) Edit: Did a quick check - clip fits but heat sink I have is WAY bigger (Volcano 7) - would fit if cut down.
