Modding sodding stupid // port LCD :(
Discussion in 'Modding' started by Guest-16, 25 Mar 2002.
  1. Guest-16
    Guest-16 Guest
    damit - it took me hours to wire up yesterday. i burnt my hand (nice big blister now), bed (mum dont know yet ;) ), floor but finally i managed to get everything wired correctly (or so according to the info i was given).
    I rig it up to the parrallel port in my dads poot and download LCD smartie and all i get is the top line (its a 16x2) filled with black squares and nothing on the bottom line. I set LCD smartie up correctly (look for // port and stuff) and still no go :(:sigh: :cries: :cries:
    any other software which is better?!?
  2. Cheese
    Cheese Doc
    6 Oct 2001
    Try lcd center... black line is a test bar and should appear on power up, so that's good.
    Looks as if she's not getting data, so if the r/w select (pin 5) properly earthed? How about the strobe, pin 6 (parallel pin 1)? And finally the reg select, pin 4 (parallel 16)... if any of these are wrong then data wouldn't get to the display.
    Don't forget to install port95nt (in you're using xp/2k) as well as lcd center before trying... cheers,
    Rob.
  3. Guest-16
    Guest-16 Guest
    Its in 98se atm (didnt know about prime95nt, so when i come to use it on my machine with xp ill install that).
    Thank you about the test bar info!!!:lol: :) that's made me feel happier that my soldering skills are ok :D
    Here's how its been wired:
    LCD Pin : // Port Pin
    1 : earth
    2 : +5v
    3: earth
    4: // 16
    5: earth
    6: // 1
    7: // 2
    8: // 3
    9: // 4
    10: // 5
    11: // 6
    12: // 7
    13: // 8
    14: // 9
    Ill double check the earthing cause i havent properly rigged up a molex yet - the wires are just pushed into the psu molex.
  4. j03
    j03 What's a Dremel?
    14 Mar 2002
    Do you know where you can get molex's ? Ive been wiring up my VFD but i dont have one so i was going to tape the wipes into my femaile molex :)
  5. Guest-16
    Guest-16 Guest
    got a maplins near you?? they do them in there.
    or goto www.maplin.com (or .co.uk, i can never remember).
    Rob - LCD center "could not initilise display" then when i fiddled with the power cable and tryed it again "runtime error 48, could not find dlportio.dll" :( :cries:
    /me goes buys a serial LCD nexttime
  6. Cheese
    Cheese Doc
    6 Oct 2001
    maplin and lots of modding stores sell them... farnell do too but I wouldn't like to try and find them again ;)
    Cheers,
    r.
  7. Cheese
    Cheese Doc
    6 Oct 2001
    lol I think you might have to install port95nt anyway then... just follow the lcd center installation instructions.
    r.
  8. Guest-16
    Guest-16 Guest
    Now im getting an LCD center error "subscript out of range" "runtime error 9" even with 95 VB running bah :grr: st00pid thing. i cant even reinstall it to get it to work now :(:(
  9. Cheese
    Cheese Doc
    6 Oct 2001
    not good... lcd smartie should work tho...
    I'd go delete all the lcd center reg entries, delete all it's files and reinstall.
    Cheers,
    r.
  10. Guest-16
    Guest-16 Guest
    ok
    /me hopes i dont f00k my dads pc with regedit :blush:
