Apple Software for my iphone
Discussion in 'Software' started by shane1986, 4 Feb 2009.
  1. shane1986
    shane1986 What's a Dremel?
    4 Feb 2009
    Hello Dear Readers,
    Thank you very much for being in this page, well I recently bought a iphone 16Gb from this place called ExoticPhone but i think i have a problem with it, I bought the unlocked one thats why I lost a few of its features, MMS doesn't work with my iphone its so disappointing..... Anyways the bigger problem with it is that it gets unlocked every now and then, I actually didn't know why it used to get unlocked but this guy from the tech department of exoticphone told me that, when ever I'll try to download something through itunes my phone will get locked...
    Guys can you help me out, is there any software that can help me unlock my iphone permanently...
    Thanks for reading guys.... Have a great day.......
  2. wyx087
    15 Aug 2007
    MMS was never an feature of iPhone, should have done some research before you bought it. :)
    i can help you unlock it if you contact me through PM with details of your operating system and iPhone version (3G or not? )
    iPhone will NEVER lock itself when you download stuff through iTune, it will, however, lock itself when you do firmware upgrade, that is the ONLY occasion when it locks itself. so all you need to do is to use custom-made firmwares and everything will be permanently unlocked.
