Electronics solder, heat help...
Discussion in 'Modding' started by Ouikikazz, 20 May 2002.
  1. Ouikikazz
    Ouikikazz What's a Dremel?
    13 Apr 2002
    OK the problem i got is when I soldered my resistor's to my LED's project and then i light up the led using a 12v (this project requires a 12v) the solder itself starts to melt then eventually parts from the led pin therefore I got to resolder the stuff together. It seems that it is getting too hot, is this normal, what should I do? I was thinking adding vent's then a small fan just to keep the solder from overheating then falling off. Would like to hear what you guys think
  2. GJUK
    GJUK What's a Dremel?
    10 Apr 2002
    erm that sounds like its gettin WAY too hot, u sure its wired up right ? :eyebrow:
    if it is, try a 120mm delta? :D
    Jono
  3. Ouikikazz
    13 Apr 2002
    i'm sure i wired it up correct, it gets too hot to touch when it's on...I want to try 5v but i'm not sure if it'll affect the project....
  4. x24
    x24 What's a Dremel?
    9 May 2002
    Can you give us the specs of the LED in question? we need the operating/forward voltage and the current rating (mA) and the value of the resistor you used.
  5. Ouikikazz
    13 Apr 2002
    heh...u kno what? it works fine under 5V...I just referred back to my project notes and I realized it was originally designed for 5V...LOL stupid me.
  6. GJUK
    10 Apr 2002
    :) always read the instructions :p
    nvm, glad its wokrin fine now :) :dude:
  7. tonyz
    tonyz What's a Dremel?
    17 Feb 2002
    wow, a self correcting mistake. gets too hot and it blows its own fuse.
