Electronics Soldering Iron
Discussion in 'Modding' started by MrShake, 14 Nov 2003.
  1. MrShake
    MrShake What's a Dremel?
    3 Nov 2003
    I am a horrible solderer, and the tip on my iron is coated
    in lumps of solder and the such.. I've gotten better at
    soldering, but my iron is getting in the way.. is there any
    way to clean the tip or otherwise revive it without replacing
    it??
  2. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    You should always clean your soldering iron by pushng it onto a wet sponge after each joint, apart from the last one, leaving it tinned helps protect it.
    If you have any of that metal wool/scrubber in the kitchen you can use that to scrub it up nice and neat.
  3. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    What I usually do after I solder is get low grit sandpaper and with one rub, take all the foreign particles off the tip. This will usually expose the next layer of the tip which you can then "tin" the tip for your next project. Although don't do this with those expensive tips, my tips cost $2.47 for 2 so I usually do the above to clean them.
  4. Kermet
    Kermet [custom title]
    18 Feb 2003
    Just be careful you don't go past the coating and into the bare metal...
  5. fump
    fump What's a Dremel?
    14 Aug 2003
    you can buy a little pot of tip tinner/cleaner. it does what it says on the tin and it smells abit like sugar when its burning. :lol:
  6. Xiachunyi
    3 Nov 2003
    Oops, I think I already did. What will happen if I go past the bare metal?
  7. MrShake
    3 Nov 2003
    Well, I just pushed on with a light sanding, going to go get new tips tommorow sometime as they are cheap and then be nicer to the new ones..hehehe
    Thanks!
  8. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    I don't think it is that bad, when my soldering iron got too badly eroded, I just took it to a pedistal grinder, and took it to bare copper on the tip, then I tinned it right away.
    As long as the tip screws in, (no heating element in it) you could sand/grind it as far down as you like.
    As far a sponges and whatnot, I like to take a whole bunch of toilet paper, ball it, put it in a small paper cup, and add enough water so that when I presson the paper, it submerges, but when I stop pressing, the water level goes below the paper.
  9. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    Same here. I get the really cheap tips and :dremel: them down to a fine point and tin them. But when it comes to doing soldering work, the use of a wet-sponge constantly helps things alot.
  10. MrShake
    3 Nov 2003
    Thanks for all the advice guys!!!
  11. dsoh
    dsoh What's a Dremel?
    24 Dec 2004
    blowtorch for silver so;dering
    Please forgive me if I am in the wrong forum. Can anyone advise as to what type, brand ,size etc of blowtorch to use for silver solder, probably hard silver solder ? I plan to build boilers for model steam engines using copper tubes. Thanks for any input.
  12. dsoh
    24 Dec 2004
    blowtorch for silver soldering
  13. chalk_mark
    chalk_mark What's a Dremel?
    8 Aug 2004
    For a sponge, I get one of the wallpapering/kitchen pure cellulose sponges and cut it into slices like bread. Same stuff as what comes with many station irons when new. At least the ones that give you a wafer thin sponge that swells to size first time you wet it anyways. For about a 2 dollars you get a sponge the size of a small brick, and you have a lifetime supply of customizeable ( sp? ) sponges. I like the retinning paste in the little can, ( have it at work ) but was always too cheap to buy it for home.
    Oh yeah, here is some more cheapness on my part: 10 gauge copper wire for tips on my soldering gun.. 10 dollars for 2 tips from Weller, bah!.. $1.50 gets me a meter of 10/2 cable, enough for almost 30 tips.
