Modding soldering...problems
Discussion in 'Modding' started by Ouikikazz, 20 May 2002.
  1. Ouikikazz
    Ouikikazz What's a Dremel?
    13 Apr 2002
    OK the problem i got is when I soldered my resistor's to my LED's project and then i light up the led using a 12v (this project requires a 12v) the solder itself starts to melt then eventually parts from the led pin therefore I got to resolder the stuff together. It seems that it is getting too hot, is this normal, what should I do? I was thinking adding vent's then a small fan just to keep the solder from overheating then falling off. Would like to hear what you guys think
  2. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    it shouldnt be getting that hot. you either have a shory or you are using a very lo voltage led and the resistor is dissipating too much heat, try putting the led on 5v line with a smaller resistor.
  3. viridius
    viridius What's a Dremel?
    7 Apr 2002
    It doesn't sound like you're using solder. The standard 60/40 stuff melts at about 600F. Your LED still works?
  4. Ouikikazz
    13 Apr 2002
    yes my LED's are fine.
  5. Ouikikazz
    13 Apr 2002
    if I put on a 5V my resistors would be all wrong...I would have to buy new ones, I have used the suggested sizes from linears calculator
  6. Lazy
    Lazy Meow?
    13 Nov 2001
    ask in the electronics forum as you might get more replies.
