Storage SOLVED. DVD Drive not reading anything
Discussion in 'Hardware' started by pimonserry, 21 Mar 2009.
  1. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    So, I decided to reinstall Rome: Total War (3 CDs) and I put the first CD in (it's old, so a lil bit scratched, but easily in good enough condition to be read) and it goes in, DVD drive lights are on, no major spinning noise, but not silent either.
    My Computer registers that a disc has been put in (icon changes from drive to a pic of a CD) but when you try to 'open' the CD it says no disc is inserted, and ejects the drive tray.
    The same thing happens with CD2 of Rome: Total War, which is almost unscratched.
    The same thing happens with Splinter Cell: Chaos Theory, which is a DVD.
    I've checked for obvious things, like power plugged in, IDE cable plugged in to drive and motherboard, but I can't see anything.
    It's the first time it's happened, but then again I haven't used the drive in ~2 months.
    Anyone got any ideas why it's decided not to read anything properly?
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Dust bunny on the lens?
  3. pimonserry
    20 Dec 2008
    Didn't think of the lens, I'll take a look in the morning probably, 'cause I'd have to take the whole thing apart ( :( )
    Realistically, it probably is something as simple as that.
    Edit: I tried blowing into the drive while it was open, to no avail.
    Guess it will have to wait 'til morning.
    Double edit:
    Nevermind, a quick uninstall in Device Manager, reboot, then reinstall has it reading again. Fixed! Aha.
