Apple SOLVED - Make ISO from cd-rom
Discussion in 'Software' started by Lovah, 19 Apr 2005.
  1. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    Hi all,
    At school we use this program for accounting. And you need the cd to start the program.
    Now my brother typed in something in the terminal wich created a iso from the cd rom. Whenever I need the cd-rom I just click the ISO and it gets 'mounted'.
    Why am I doing this?
    Well the cd drive on my powerbook uses alot of power. So I use the ISO. I do own my cd-rom.
    What is the command to create a iso from the cd-rom.
    The reason that I'm asking is that a friend of mine who is visiting right now has a similar cd-rom for school, but they only have 1-cd-rom and they have to pass it true the class each time they start the program. So this would make it easier for him.
    Thanks very much
    L
    Answer
    http://www.macosxhints.com/article.php?story=20031225124417353
  2. antoniohawk
    antoniohawk What's a Dremel?
    21 Oct 2004
  3. Lovah
    10 Jul 2002
    no..
    It dosn't work and its not that either I think
    please somebody.. full command for makign a iso from full cd-rom on a powerbook.
    L
  4. Lovah
    10 Jul 2002
  5. -=ice=-
    -=ice=- What's a Dremel?
    17 Jan 2003
    I use disk utility,
    menu, Images --> New --> Image from (Select Drive)
    It outputs a .dmg, most of the programs i've try'd that require the disk present to run have worked fine with the dmg mounted :)
  6. Lovah
    10 Jul 2002
    Hi thanks
    if you want to mount it like a real cd rom
    then you have to lock the iso and then mount it using toast
    :D
    L
