[SOLVED] Maximus VIII Formula problems
Discussion in 'Asus UK' started by ////\oo/\\\\, 16 Jul 2016.
  1. ////\oo/\\\\
    ////\oo/\\\\ Minimodder
    16 Oct 2003
    Ok, so this is really weird...
    System build:
    MB: Maximus VIII Formula
    CPU: i7 6700k
    Mem: Corsair DDR4 3466 4x8GB (running at standard speed at the moment, not 3466)
    SSD: Samsung 850 EVO SATA (connected to SATA 1, have tried other ports)
    GFX: not arrived yet so using the GFX built into skylake
    So I've put the system together, it posts to BIOS, I can install Windows, but if I try to install any updates at all (tried ASUS MB CD drivers, ASUS online drivers, Microsoft auto updates, Microsoft manual updates), when it reboots I see the Windows loading screen, and then I lose the video signal...
    Thoughts?
  2. TheMadDutchDude
    23 Aug 2013
    The many joys of Windows 10, I'm afraid. You may need to reinstall Windows. :(
  3. ////\oo/\\\\
    16 Oct 2003
    It's a new build so a completely fresh install, I've started from scratch about 5 times now, same result every time. As soon as I try to load any update on reboot I lose video signal after the initial wondows loading page
    Also, Windows can't see the LAN connection, can only use wireless? I think that might be related to the drivers, but then when I try to install any, we're back to the missing video signal issue...
  4. ////\oo/\\\\
    16 Oct 2003
    And I've just noticed my spelling mistake in the thread title, damnit :duh:
    It was late / stupid iPad spellcheck...
    Fixed! (the spelling mistake)
  5. ////\oo/\\\\
    16 Oct 2003
    Solved!
    Video output was running through my AV amp, connecting it directly to the TV resolved the problem :)
