CPU [Solved]Removing thermal paste
Discussion in 'Hardware' started by SpaceBaby, 11 Dec 2010.
  1. SpaceBaby
    SpaceBaby AKA: Stophon
    1 Aug 2008
    Ok well the only thing i have in the house which i think would work is methylated spirits, would it work or it is overkill?
  2. djzic
    djzic Bokehlicious!
    8 Nov 2010
  3. SpaceBaby
    1 Aug 2008
    to explain my situation, it needs to be done today. im looking for advice on if it works/breaks my CPU or if there is something i can get from a supermarket or DIY store.
  4. djzic
    djzic Bokehlicious!
    8 Nov 2010
    the alchohol should work.
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Not too sure if meths will leave any residue behind.
    I use Isopropyl Alcohol which I purchased from a Lloyds Chemist (think it was Lloyds but definitely a chemists).
    Its around a fiver for a 500ml bottle.
    Lint free coffee filters are also supposed to be very good for the application although I just use paper towel and have never had any issues.
  6. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Tissue is fine!! Try that first.
    Has worked fine for me lots of times
  7. SpaceBaby
    1 Aug 2008
    ok well it seems to have removed it fine, used Q-tips and a cloth. now to apply new thermal paste to check if i broke anything.
    *fingers crossed*
    Edit: computer is now working perfectaly.
  8. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    I've always used toilet roll, ghetto.
  9. Richy1204
    Richy1204 What's a Dremel?
    7 Dec 2010
    Methylated spirits works fine :)
