SOLVED: Unable to playback 1080p videos correctly. -yes i have read the sticky
Discussion in 'Tech Support' started by Delphium, 17 Sep 2008.
  1. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Hi, as the title states, I am unable to get smooth playback of any 1080p videos.
    I have read the sticky guide, however I appear to have hit a wall and am missing something, I just cant work out what :confused:
    The sticky advises users to download 'Media Player Classic - Home Cinema' of which I have version 1.1.604.
    Then advises to set the render output to EVR which ive done.
    I have checked to see that there are no preferred H264 filters set.
    After doing this, the guide shows to open up a 1080p .mkv file and select "MCP Video Decoder"
    However mine does not show this.
    Where have I gone wrong? Have I missed a step somewhere?!! :confused:
    Thanks for any help.
  2. djDEATH
    djDEATH Habari gani?
    23 Mar 2006
    this is exactly the question i asked at the end of the sticky guide, as i have run into the same problems. first time i went through this, there were filters in the list which you could set to be preferred or not, whereas neither mine or yours have those filters in there now. still unresolved here too.
  3. Delphium
    18 Mar 2007
    Ohhh I see :(
    Thanks for the reply
    Shame...
    Well if I solve it, ill be sure to post my findings.
  4. GoodBytes
    20 Jan 2007
    wow, I can't believe you took time to to make everything around the focused windows blurry.
  5. Lemmingzappa
    Lemmingzappa What's a Dremel?
    8 Nov 2004
    add coreAVC as an external filter, and then click "prefer" and apply.
  6. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
  7. Delphium
    18 Mar 2007
