Some BallistiX questions
Discussion in 'Hardware' started by Bbq.of.DooM, 10 Dec 2005.
  1. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Ok.
    On the 2x256 kits, I would like the following info:
    1. DDR400 or DDR500
    2. Batch #
    3. PN
    4. Max oc'
    5. Voltage used to reach max oc'
    Thank you.
  2. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    2.9v should be plentiful , batch would say on the side of the box, max oc varies enormously due to multipliers mem dividers timings etc , they will be ddr400 "dual channel" untill you overclock which then say you get 250fsb that will be ddr 500
  3. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Not sure about the 2x256 kits.
    You should be good for 270 at least, with 2.7/2.8v, with 3-3-3-8 :)
  4. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    The 2x256 kits are known to do 270Mhz+ @ timinings as low as 2-2-2-7 @ ~2.8V. :thumb:
  5. Pookeyhead
    30 Jan 2004
    I concur: 512 kits should do DDR500 @ 2-2-2-5
  6. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Have a 2*256 kit here, runs to ~ 250 on 2.5,2,2,x timings with 2.7v. Havent really tested much higher than that... The P4C800 seems to max ~ 260 anyrate...
  7. Pookeyhead
    30 Jan 2004
    Of course.. it all depends on your motherboard and CPU as well.
  8. Bbq.of.DooM
    12 Feb 2005
    Alright. I'm having some minor problems:
    ASRock 939dual-sata2
    Opteron 146 CABYE
    The Ballistix is registering at 170mhz, 2-2-2-5-7-11. Not too sure how to get it way up. Not too familier with the bios options for dividers and voltages. Help?
  9. Pie_uk
    6 Apr 2005
    170, thats low, use a mem ratio of 1:1 i.e. ddr400 yours sounds like it is set to 333
  10. Highland3r
    25 Jul 2003
    The bios options on that board are limited, how are you finding out its running at 170? Thats a rather strange divider unless you're overclocking the FSB a little...?
  11. Bbq.of.DooM
    12 Feb 2005
    I'm oc'ing the FSB quite a bit, from 200 to 240. In CPU-Z, it says 170mhz. I also don't know where the options are lol.
  12. Highland3r
    25 Jul 2003
    OK yea its running a 166 divider for some reason, you dont happen to have 4 sticks in do you?
    You can use A64 tweaker in windows which should sort things for you... If not there may be something un-lockable in bios....
