Ok , Sup !! How ever I have some Q Can I Build case with alum.. + wood + plastic + Fiberglas ! I mean can I put the Paste between them and make they smooth and sand and ready them for paint !! Mean I have ( alum... + Wood ) can they Paste together ~ with what ??? how ?? Also I have ( alum + Plastic ) can they Paste together ~ with what ??? how ?? Thanks !
epoxy,resin,pritstick,tape, andythign lmao naa get soemthign really strong liek 5minute epoxy? that woudl sork stick everythign to anything!
umm i dunno, 5 minute epoxy i think you cna paint on no prbs, and i cant see there being a problem with sanding! epoxy sounds gd to me. make sure its 5 minute becuase u cna get 60 second, but it dries in that time, and you need long enough to move it around! use it to stick almost anything to anything! Just watch ur fingers, cus once them stuck them stuck.
you can, but because of the nature of wood and aluminum it won't be the strongest hold, in the long run it would be better to screw or bolt the 2 pieces together
Because I was think to built the custom part from wood ! because the vibration and the heat !! Check What I was mean on my project Log And Thanks man To Clear this for me
