Windows some quick questions on remote desktop
Discussion in 'Tech Support' started by chrisb2e9, 3 Apr 2009.
  1. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    Hello, Being away from home for a week at a time I often wish I could do something on my computer at home.
    How well does remote desktop work?
    One of the things I wanted to do this week was go on and delete the history of internet explorer. Would I be able to do something like that?
    Can I transfer a file from the home computer to my computer at work?
    And last if someone is using my computer at home, will they know if I am using it through remote desktop?
    Thanks
    Chris
  2. Glider
    Glider /dev/null
    2 Aug 2005
    Very well actually, but it isn't very secure (nothing to be pedantic over)
    You can do most things you could do if you were at the system
    Yes, you can set it up (client) so your local drives show up on the remote system, it won't be very fast tough...
    They'll get a notice, and are logged off.
    chrisb2e9 likes this.
  3. chrisb2e9
    18 Jun 2007
    Ok, thanks for the direct answers!
  4. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    how well does it work ?
    its great for anything office and general windows based.
    explorer history is not a problem
    with windows remote desktop you can just right click on the file and click copy then paste it onto the current machine your limited to upload speeds tho
    in terms of other people knowing im not sure on this but it depnds on how you set it ip i know VNC can just take control of the mouse but with remote desktop you can create a new session or log off the existing i beleive i only ever take control of my machine at home which no one else uses and is monitorless or a machine at work which allows multiple sessions
  5. GoodBytes
    20 Jan 2007
    Things be careful at... Make sure your computer that you connect to has a strong password. Also, don't confuse between systems. What I mean is, once I remote desktop to my computer and wanted to print some work. So I printed something without the print dialog box (quick print). In result, I just printed my work on MY printer at home. So, yea.. watch out for that, and do a normal print procedure with the dialog box to select the printer from where you actually are so that remote desktop does the transfer and prints it on your local machine instead.
  6. Jenny_Y8S
    Jenny_Y8S Guest
    On consumer OS's (XP, Vista etc) you only ever have one session, so only one person can be logged in at a time. If you log in via remote desktop (MSTSC) then you will log off anyone logged in locally. And the same works the other way round, they can log back in again and log off the remote user.
    In windows server OSs, then you have more sessions. The minimum is usually four. Two standard "client" licences plus console & admin.
    For a bit of remote admin remote desktop will do fine, if you are connecting over a slow connection then limit the window to 640x480 and 256 colours. No need for full screen 32bit if you're just making some config changes.
    Hope this helps.
  7. chrisb2e9
    18 Jun 2007
    Thanks everyone.
