Modding some top window ideas
Discussion in 'Modding' started by pranks7er, 5 Sep 2003.
  1. pranks7er
    pranks7er mange tout
    25 Dec 2002
    hey ppl i need some top window ideas (really kool ones) for my upcomming project any ideas
  2. Scellica
    Scellica What's a Dremel?
    3 Sep 2003
    just search a logo or sign you like. Or keep it simple (round, rectangular, ...). You could also @ a blowhole (80 mm fan). It's your case so use your own ideas :D
  3. Thunder_return
    Thunder_return What's a Dremel?
    8 Jun 2003
    Do like this: You decide a logo e.g Flames and then you mirror it
    so you will have 2 flames, like this:
    ! T T !
    ! h h !
    ! e e !
    ! T T !
    ! O O !
    ! P P !
    ------------------------------------------ Sorry for my painting! LOL!
  4. Lithium
    Lithium super spunk
    26 Jul 2002
    Here is mine...pretty plane but gives a nice effect with the mesh with tinted plexi under neath now.
  5. pranks7er
    25 Dec 2002
    thats kool :thumb:
  6. Mister_Tad
    27 Dec 2002
    this picture is well old but i still have the same windows in it, completely diff hardware and lighting though, but the windows are the same. now theres an EL string going round the edges of the 3 windows to make the etch light up, the effect is pretty sweet
    the wave is from a painting by hokusai, appropriately called the great wave
    dont just do a rectangle window with a generic etching though
    custom all the way!
  7. pranks7er
    25 Dec 2002
