Hi guys, just need some quick confirmations on the following WC issues: 1) got myself CPU and VGA blocks with 10mm fittings, so i figured out i'd get some 3/8" ID 5/8" OD Tygon tubing, correct? 2) single HW-BIX with 3/8" fittings, fits that Tygon right? 3) Danger Den DD12V-D4 or the MCP600 pump, both have Standard Inlet and outlet 1/2" OD, what ID does that translate to? Will it fit the above mentioned Tygon? Which one would you guys choose? Thx, edit: i see that FrozenCPU has 3/8" ID, 1/2" OD Tygon, i assume that'll fit on all the parts.
Should all be ok. you may have to heat the tubing up in some boiling water to get it over some of those barbs but at least it will be tight I dont get the MCP600 cous it says 1/2id tubing but then swiftech use it in kits with 3/8id tubing i assume you just have to strech it over.
Thanks for your input. I might go for the MCP600, hope it is the trouble free revision. The DD-D4 appears to be quite noisy. Anyone got hands on experience with the Alphacool AP900 Kreiselpumpe 12Volt? And are heatercores better than normal radiators?
