Windows Some websites (ebay.com) not loading
Discussion in 'Software' started by 220689JC, 1 Sep 2005.
  1. 220689JC
    220689JC What's a Dremel?
    25 May 2005
    I NEED HELP :waah:
    my IE (Firefox) will load certain web pages such as Google but it will not load other ones such as ebay. all it comes up with is "waiting for www.ebay.com" then just does nothing :wallbash:
    so PLEASE help
    P.S luckly it loads Bit-Tech :clap:
  2. atanum141
    22 Jul 2004
    seems like its timing out.....
  3. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
    It could be a firewall that's blocking ebay?
    Do you have one running? It may be wirth checking the settings.
  4. CarlT2001
    CarlT2001 What's a Dremel?
    23 Jul 2004
    Clear your cache, then check again...if nothing, your ISP may be having a problem.....
  5. funkymunky
    funkymunky Guest
    mine does almost the same.. with msn messenger.. i cant open my emails from the link in msn. It just does as 220689JC pc does. But if i go onto hotmail directly it works :S weird!
  6. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    If you are in the uk and you use a router, it looks as though you have the encapsulation setting set to poppe (or whatever is is) where it should be set to PoPPa. I had that problem once. Hope that helps.
  7. funkymunky
    funkymunky Guest
    would this apply to both of us?
  8. 220689JC
    25 May 2005
    thanks for our help but i still have the problem???
    i tried the router thing and nuthin!!!
  9. 220689JC
    25 May 2005
    the encapusaltion setting is set to
    PPPOA (PPP over ATM)
    or i can have
    PPPOE (PPP over ethernet)
  10. DivineSin
    DivineSin What's a Dremel?
    23 Apr 2004
    Are you using bittorent when this happens? Does a restart fix it? What webpages wont load (other than ebay) and what webpages will load?
    If google is the only page that loads, its probly because its just in your browsers cache.
    If your downloading several things in bittorrent when this happens, this is a common problem as bitorrent is using too many connections.
  11. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    If you are still having this problem, it is likely that your DNS server ain't working properly or something, that is the most common cause of some webpages not loading. Try changing it if you can or refreshing it.
  12. 220689JC
    25 May 2005
    well im not using bit torrent and i tried restarting my router but that didnt fix it.
    it will load candystand.com , bit-tech and many others but it will not load things
    like ebay.com and hp.com and msn.com , hotmail.com.
    how would i go about changing or refeshing my DNS server
    thanks
  13. cpemma
    cpemma Ecky thump
    27 Nov 2001
    So IE = browser? Watch out for Quack :worried: :hehe:
