someone needed to unlock my XP
Discussion in 'Hardware' started by gavin16, 4 Oct 2002.
  1. gavin16
    gavin16 What's a Dremel?
    5 Aug 2002
    i have an XP1600 which i'm having trouble with i bought it 2nd hand and the person before me tried to unlock it, it has now got multiplier problems on start up it loads @ 6.5 instead of 10.5 sometime after cleaning it it will start @ 10.5 . Anyway the CPU is useless to me unless i can get this sorted so i need someone willing to give unlocking it a try, Anyone want a shot ? i won't hold you responsible for breaking it as it's already pretty ropey i just need someone experienced to give it a go. Please :D
  2. [CpK]Bastid
    [CpK]Bastid What's a Dremel?
    24 Aug 2002
    I'd ask for a refund...or did you know bout problems beforehand?
    nevermind...i didnt read carefully:wallbash:
  3. gavin16
    5 Aug 2002
    i never knew about it before hand and it worked fine when it arrived so i never kept note of the guys address. It's a green CPU if that makes a difference ?
  4. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    theyre better at overclocking im told...
    read a lot of guides and then try again...:idea:
  5. gavin16
    5 Aug 2002
    Yup the CPU is a great clocker when the multi's are working right seen it do XP2100+ speeds stable :)
  6. Moo
    Moo What's a Dremel?
    19 Aug 2002
    If the previous owner tried to unclock it with silver paint you can remove this with a pencil eraser or carefully scrape it off with a razor blade. Than at least you'll have a relaible chip.
    Heres a link to an overclock map for the XP http://www.ocinside.de/go_e.html?/html/workshop/socketa/tbred_painting.html
    A Google search for unclocking should give many how-to guides
