Build Advice Sometimes I really hate PC's
Discussion in 'Hardware' started by Kronos, 13 Oct 2014.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    This afternoon I have added a second GPU, swapped a HDD for a bigger one added a couple of cold cathode lights. reconnected everything and I get the message "Reboot and Select proper Boot Device or insert boot media in selected boot device and press a key." WTF.
    So far I have disconnected the two HDD's that are not my boot HDD which is a Crucial M4 SSD. It is seen in the BIOS it is my first boot device yet it is bot booting.
    Any advice before I reinstall?
  2. TheMadDutchDude
    23 Aug 2013
    Did you have the old HDD plugged in when you installed this current install of Windows? If that's the case, I'm willing to bet that it will boot if you plug it back in. :)
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have no idea but I will Switch HHD's to see if you are correct but that hardly solves the problem. As the HHD's I switched only had my Steam installation on and I cloned it to another bigger drive.
  4. TheMadDutchDude
    23 Aug 2013
    I take it you're running Windows 7. Is that right?
    Basically, Windows has a really ****ty habit of installing the MBR on to another drive other than your SSD if you leave them plugged in during the install. It makes absolutely zero sense to me and the only real way to stop it from doing it is to disconnect every drive apart from the SSD during installation.
    My Dad's machine is the same. If I remove his data drive, a HDD, the system will not boot, and it is the same in some other systems that I've done before too. The MBR, for whatever ridiculous reason, installs on the HDD.
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    OK mate cheers. I going for the reinstall. Thanks again.
  6. bawjaws
    bawjaws Multimodder
    5 Dec 2010
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
    I started the reinstall but the reread the posts here and have stopped it whilst I disconnect the secondary drives. Doh.
  8. ceryni
    ceryni Idiot
    6 Jul 2011
    I was getting a similar problem with mine when I was building my PC, putting partitions on my DATA drives. I disconnected everything and installed with SSD only connected...
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    Doing that now or rather installing the mucho updates. It's a bloody nuisance though.
  10. Pookeyhead
    30 Jan 2004
    Next time you do a Windows install, do it with only one drive (your intended C drive) installed to prevent this in the future.
  11. davidbrown1988
    davidbrown1988 Minimodder
    8 Mar 2008
    I've had this issue more times than I can recall, I never seem to remember to remove all other drives when installing. Windows always seems to store the MBR on another drive when there is more than one drive present.
    I've fixed it every single time by just inserting the windows install disk and repairing the installation. Worth noting for next time as it'll most likely save you from a full re-install.
  12. Parge
    16 Jul 2010
    Why in God's name, does windows do this?
  13. TheMadDutchDude
    23 Aug 2013
    It's Microsoft. That's all I can come up with. :D
