Modding Sometimes I wonder if I ask for too much...
Discussion in 'Modding' started by McGarnacle, 9 Aug 2002.
  1. McGarnacle
    McGarnacle What's a Dremel?
    7 Mar 2002
    Hey everyone, two quick questions, one probably easier than the other...
    first, to convert a laptop dvd drive to work under a standard system setup (standard pc instead of laptop) what would you need? Is the data cable/connector and voltage the same? I assume Mashie would know the answer after Anenome (wicked WICKED job there btw) and the rest of you boys too prolly...
    and second, is there such a thing as a ribbon pci slot adapter that would allow a pci card to be connected somewhat akin to an ide drive? I have a home system cd player i want to convert to a pc, but the flex atx mobo i have has crummy onboard sound, and i want to use an extra soundcard i have. The case is rather slender, so I cant just slap it on, it would be way too tall, BUT, if it had an adapter that allowed the board to connect, but still be parallel to the board, it would be perfect.
    Any chance this exists somewhere? I live in North America and have heard of nothing of the sort...but with modders taking over the computer world, perhaps it has been born some beautiful place far away?
    cheers all.
  2. Fronzel
    Fronzel What's a Dremel?
    9 Mar 2002
    >DVD Drive from a laptop
    It isn't the same connector, but there is an adapter cable you can get.
    >PCI Thingy
    There are riser cards that will do that, if that is what you want.
  3. Ubermich
    Ubermich He did it!
    21 Jun 2002
    this is the answer, sir.
    risers wern't all that cheap the last time I checked, but they are the solution. There are standard risers and flexible risers. The problem w/ the standard immoble risers is, sometimes they can cause the card to bump into the cpu heatsink. However, I think (if my memory serves me) that the standard ones are slightly cheaper than the flexible, if you can use them.
    (will look for linky...)
  4. Iamgoodyy
    Iamgoodyy What's a Dremel?
    11 Nov 2001
    Link for convertor from Laptop CD Rom to IDE rom found here
    I never ordered one. But I think others might have.
    Iamgoodyy
  5. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    as for the drive adapter, ive used a very similar looking adapter to use a laptop HDD inside a household PC.. worked nicely.. as for a flexable riser, im sure they exist, but ive never seen one..
    -scoob8000
  6. Iamgoodyy
    11 Nov 2001
    Ran across this link in my bookmarks - here
    Is that what you are looking for?
    Iamgoodyy
  7. Phire
    Phire Performance-PCs.com
    11 Jan 2002
  8. mashie
    mashie The one and only
    15 Mar 2002
    Ok, to get a slimline CD/DVD to work is quite easy.
    Step 1: Get an adaptor, se link posted above by Iamgoodyy.
    Step 2: Remove the current connector that the laptop manufacturer has mounted on the back of the cd-rom to make it proprietory (it is two layers of connectors on the back) remove the outer one by unscrewing the two screws closest to the edges and you will find a small standardized connector under it. All you need to do is to attach the adaptor, plug in the power, audio out and your normal IDE cable.
  9. Enak
    Enak Also known as Kane
    23 Jul 2002
    Do you have the pinouts for the slimline drive?
  10. mashie
    15 Mar 2002
    No, just get one of those premade boards since you will have a hard time to get the proper connetor anyway...
  11. Enak
    23 Jul 2002
    I was thinking I could take the connector off of an old HDD.
  12. mashie
    15 Mar 2002
    It's not that connector that is hard to get, it is the other one facing the CD-ROM that is a bitch.
    You are only wasting time and money trying to do it yourself...
  13. Enak
    23 Jul 2002
    Whats wrong with removing the one on the CD drive?
  14. mashie
    15 Mar 2002
    Actually I think this is an excellent idea, it is after all only 40 pins, power and audio out you need to solder. And that all those pins ends up at a connector 1" wide will just make it more interesting.
    Good luck and post pics when you got it working.
  15. Enak
    23 Jul 2002
    :lol:
    Free... or $25 + shipping (to UK)... I figured making my own would be cheeper...
  16. mashie
    15 Mar 2002
  17. Enak
    23 Jul 2002
    Cool.. thanks for that Mashie :)
    Guess I will send off an email and get the pricing checked.
  18. Enak
    23 Jul 2002
    Got this email back this morning:
