Sorry to hear about your busted dremel. Seeing that purple the other day went straight to my head and I didn't notice you was using a GTX285. I have a pair of EK Nickel/Acetal GTX285 blocks for sale if you are interested give me a shout. It's one of these if you want to check if it will fit your card. Shiny!
Sleeve! Hi all did just recive my mail and did get a little packege. I was some sleeve from one in sweden that just hade open his shop whit sleeve. and i did first think it was like all other **** sleeve from sweden, where you can see trugh it all but to my suprize the sleeve was as good as Mdpc-x´s sleev so tumps up for this pix´s will come later today on the sleeve and my computer that i just riged up untill my case is done Sorry for the english is in a hurry //Dahl1n
The pix´s i did promes Here are the pics on my computer: And the sleeve i did recive today: No more work on this taday but i think i will make some tommorow //Dahl1n
Now it´s time for update Hii everyone! The project has received a name Somnium Purpurea! (If anyone knows what that means you get a little gold star haha) Do apologize for that I have not updated the build log. I've bought a new dremel but this time it was not genuine and it's clearly quite a big difference But now for some pictures and other things My plexiglass plate which I got today: Now to work as I have done today. I have sanded a heldel to get my new back page. and here are the results: And now for my idee to do so that my back side looks to be original: What I have used to secure the Biltema Steel epoxy. And I can say that it is so incredibly hard. right now I did a test in order to pry loose aluminum piece, but it did not go after the chassis was bent instead. I will try tomorrow to sand away any excess glue and make sure my new back plate before I attach it to. / / Dahlin
Hi all a small update! Hi all! I have had little problem with money for the project and therefore it has stood still. but now there will soon a small amount and I will get the project again What has happened but I do not have any photos of is that I have tested five different pieces of epoxy adhesives. Unfortunately, none of them worked. but now after several hours of searching, I found this : Some small facts about it: Uhu plus endfest 300 High-strength two-component epoxies Materials Metals, glass, reinforced porcelain, ceramic, wood, marble, stone, concrete, glass and thermosetting plastics, rigid PVC, rubber, plastic foam as Styrofoam ®. Not suitable for bonding large areas of glass. Processing Surfaces must be dry, dust and grease. Smooth surfaces roughen. Binder and hardener in a 1:1 ratio (equal to long threads) mix. Self-adhesive on one side, apply both sides with coarse material. They fit perfectly, without pressing. Note warnings on the packaging. Pot life: Depending on the quantity and ambient temperature. At room temperature about 2 hours. Cure: Curing time is temperature dependent, with the ultimate strength can be increased by heat (not above 200 ° C - see table). Curing temperature strength 20 ° C 12 h 1200 N / cm 2 40 ° C 3 H 1 800 N / cm 2 70 ° C 45 min 2000 N/cm2 100 ° C for 10 minutes in 2500 N/cm2 180 ° C for 5 min N/cm2 3000 10 N/cm2 = 1kg/cm2 This is where it all for me to be ordered on Monday and hope I get it in near future (Hope you will keep my fingers crossed with me) and last but not least, my incredibly ugly signatures that I have done: Which is better? If any kind soul wants, to make me a nice signature i will be so happy / / Dahl1n
