Notebooks sony bios
Discussion in 'Hardware' started by Boswell, 3 Jan 2006.
  1. Boswell
    Boswell Minimodder
    23 May 2005
    hi how can you view the options for the bios on sony laptops? - as far as i could see pressing delete didn't do anything
    thanks in advance
  2. Glider
    Glider /dev/null
    2 Aug 2005
    Maybe F2 works, does so on my Acer, or Alt+F2, or F12... you can try that...
    Greets Glider
  3. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    F4 on some laptops too! Most likely F2 though.
  4. Boswell
    Boswell Minimodder
    23 May 2005
    ok will try once my sister is off..
  5. Boswell
    Boswell Minimodder
    23 May 2005
    ok F2 worked... how do you change the cpu value (fsb etc) or is this thing completly block you
  6. Boswell
    Boswell Minimodder
    23 May 2005
    no one own a sony notebook and has overclocked ?
    edit:[spam] ray landmark 321 posts :rock:
  7. fev
    fev Industry Fallout
    13 Aug 2003
    most laptop bios's if not all are locked down like most computer supplier's eg: dell, sony, packard bell rah rah rah
