SONY DRU500a problem
Discussion in 'Hardware' started by M_D_K, 18 Mar 2003.
  1. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    I've got a Sony DRU500a DVD writer and for some reason i can't write DVDs any more. I've recently upgraded my mother board to a abit KX7333, i used to own a KR7A-raid and now it doesn't want to do any DVD burning now i've got new mobo. Why could this be im using the latest version of Nero and i've upgraded the firmware on the drive but still nero seems to crash when i go to burn a dvd or it just freezes.
    Any help would be nice
    thanks
  2. Jaz
    Jaz Banned
    18 Dec 2001
  3. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    what ones do you suggest
  4. Necrosis
    Necrosis What's a Dremel?
    8 Mar 2002
    Have you updated Nero recently? If so that might be your problem.
  5. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    im using the same copy as i had on my computer before exept now its not working
  6. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Ok the dvd drive isn't reading dvds either i just checked
    any ideas
    Edit - I've changed the ide port and the cable
  7. Necrosis
    8 Mar 2002
    This is a shoot in the dark. Did you install the IDE drivers for your board? If you so you might try going back to the original MS drivers.
  8. banished
    banished Necromodder
    6 May 2002
    Are you still using the same intall of windows from before you changed motherboards? I have run into very few instances where this did not cause a problem.
  9. Moo
    Moo What's a Dremel?
    19 Aug 2002
    Double check all cables, power and ide. Make sure cable ends are correctly orientated and that no ide pins on the motherboard socket are damaged.
    Changing a motherboard can confuse windows, may need a reinstall but leave that option till last.
    Does dvd show up anywhere in windows > control panel > system?
