Equipment Sony DSLRs Thread
Discussion in 'Photography, Art & Design' started by phinix, 7 Jul 2008.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Hi,
    didn't see any threads about Sony dSLRs here. I wonder how many of you guys have Alpha cameras and enjoy them?
    I bought one month ago - A300 with kit lenses and this is my first dSLR and second digital camera in my life, so I'm pretty impressed now with all opportunities that SLR gives...
    So here's a Sony dSLR thread - place we could share our experiences with those cameras:
    Do you like alphas?:D
    What kind of lenses do you use?
    Any photos you would like to share here?
    Please share here with us:)
  2. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    As a long time (25 years +) Minolta user last Christmas I added an A700 which I've been very happy with, indeed the longer that I use it the better I like it.
    Typically I use telephotos e.g. Sigma 100-300mm f4.0 EX IF, Minolta 100-400mm APO, Minolta 500mm AF Reflex & am hoping to get the new 70-400mm G that is supposedly due out in August.
  3. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    I bought an a350 (with kit 18-70 lens) a fortnight back. Due to poor weather I haven't had much chance to use it.
    I've uploaded a few photos I took last Friday on my nephews school trip to Folly Farm. I love it so far, I just need to save and get a few more lens types.
  4. phinix
    28 Apr 2006
    Wow.. 500mm AF.. nice.. where do you use it? Can you show some pictures made witht that lenses? Any of your pictures?
  5. phinix
    28 Apr 2006
    I have a question - what is use of that AEL button? When may I need to use it?
  6. ~Link~
    ~Link~ What's a Dremel?
    19 Jan 2005
    If the Sony uses any of the same logic as my Nikon, that button will be for your Auto Exposure Lock. After you focus/meter your shot, you can hold down that button, and recompose, without having the camera re-meter for the new position.
    Example:
    If you had a brightly lit subject, and a poorly lit background, point the camera right at your subject, focus/meter, hit the AEL, recompose so your subject is off-center, and shoot. Your subject will be properly exposed.
    If you didn't use AEL, your camera would have re-metered on the dark backround, and set your exposure for that. So you would end up with a nicely exposed background, but the subject would be blown out.
  7. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    ^ yep! But it's only for when you use the Auto programs (P, S, A). You should be in M, where AE-L doesn't have any bearing, since you are deciding what the exposure should be. Now on a Nikon, the AE-L is usually also the AF lock, or can be reprogrammed to be one or the other. AF-L is very useful when shooting in Continuous mode.
  8. BUFF
    25 Mar 2005
    aperture priority & shutter priority have their uses which is why they were invented ;) & I'm sure that you will find plenty of pros that make use of them too.
    you are still in control of choosing what you deem to be the most important factor for your creative process (e.g. aperture for dof or shutter speed for motion).
    I'm not saying never use manual but neither am I saying never use A or S.
    phinix, I basically use the 500mm on my 2nd body as a backup to the 100-300 for when that isn't long enough.
    I'll see what I can dig up taken with it. The reflex is perfectly acceptable but isn't quite as good as a normal high quality 500mm - then again it's a fraction of the size, weight & cost.
  9. phinix
    28 Apr 2006
    Can you show some examples of photos taken with 500mm? Not even asking what was the price of that glass:)
  10. phinix
    28 Apr 2006
    OK, so about that AEL - I thought that pressing shot button to alf will keep all settings and then I can move camera to change the site.. ok, so I need to press and keep AEL also.. hmm.. need to try it..
  11. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    I've got a KM 5D (pre-sony buyout) and it gets a LOT of use. Been using the same Tamron 28-300mm lens for almost a decade and got a 19-35 a couple years ago. I love it, but if I were buying a new body now I would get a Nikon simply because they have been using the same mount since the beginning of time and I hate Sony.
  12. Jumeira_Johnny
    13 Nov 2004
    No. If your camera is still set to default, when you press the shutter button 1/2 way, your camera's auto focus will lock onto the spot where you have the AF point selected. So long as you have the shutter button 1/2 pressed, your AF is locked, so you can re-compose. It you are using any of the auto functions- P, S, or A- then your camera will adjust the exposure of the scene as you recompose- the degree depending on if you are in matrix, center weighted, or spot metering. The auto exposure functions are dynamic, so they don't stop working....until you hit the AE-L. If you are having a hard time with this; I, again, recomend you move to Manual exposure. In M, when you recompose, the exposure does not change from what you have set it to. That way you understand what is happening and what you need to change. Not understanding why the camera is doing what it is doing can rapidly lead to frustration.
    As BUFF points out, Shutter and Aperture priority have their uses. And, yes, I use them too. But if you have no idea when to use them, or what they are doing and why; then stick to M. And dear god, P is only for when you are drunk, or hand your camera to other people.
  13. BUFF
    25 Mar 2005
    I'm not sure about the A300 but normally you have the option to set the AEL button so that you have to keep it pressed to retain the exposures setting or as a toggle (press once & it holds, press again & it reverts).
    Toggle is usually more convenient to use as you don't have to constantly keep pressing the button but you must remember to press it again to release or all your following shots will be shot using that exposure setting.
    It's a niche product but there are some user reviews of the 500mm Reflex http://www.dyxum.com/reviews/lenses/reviews.asp?IDLens=25 & some images http://www.dyxum.com/dforum/forum_posts.asp?TID=11513
    I picked up mine as a mint s/h sample for £200.
  14. flibble666
    flibble666 sorry i am dyslexic
    7 Apr 2002
    i have a dynax 5d pre minolta sony buy out love the camra
