Other Sony PS5 teardown
Discussion in 'Hardware' started by Guest-44432, 7 Oct 2020.
  1. Guest-44432
    Guest-44432 Guest
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    PSA: There's a really loud noise in the first few seconds!
    But did you notice it? That uses liquid metal for the TIM...
    Edit: dammit, they discuss it later on! :duh:
  3. Gareth Halfacree
    4 Dec 2007
    I cannot express strongly enough how much I would hate to be the person in front of the camera. I'm cack-handed at the best of times, but doing a live teardown? Nope, I'm outtie. Peace.
    Guest-44432 and Bloody_Pete like this.
  4. Bloody_Pete
    11 Aug 2008
    He's probably done it hundreds of times though...
  5. Gareth Halfacree
    4 Dec 2007
    I've used a screwdriver a billion times or more, doesn't mean I don't sometimes strip a head or drop the bleedin' thing.
    Mr_Mistoffelees and SuperHans123 like this.
  6. Bloody_Pete
    11 Aug 2008
    More care, less speed :p Just imagine its all very delicate and super expensive prototypes! Thats what taught me, a few years of working around that kind of gear and I am very careful and delicate now! It only cost a few grand in destroyed equipment :p
    Gareth Halfacree likes this.
  7. Guest-44432
    Guest-44432 Guest
    I would feel confident in doing the teardown. I mean, many years ago, I stripped a £3.5K laptop on day one of it's arrival. It hasn't stopped me since.
    I have to say, I think the cooling looks pretty impressive on this console.
    Bloody_Pete likes this.
  8. IamJudd
    IamJudd Modder
    30 Oct 2011
    Have to agree - after taking the PS4 apart well into the 30th time to clear the dust from it, it's nice to see the removable parts making it easier to clean. I'm not sure if we will end up going down the PS5 route though... it's too goddamn big! Plus Games Pass seems like a winner even before the Xbox comes out!
  9. adidan
    25 Mar 2009
    Mmmk. Think i'll hang on for the Slim variant as per usual...
  10. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    It's a heck of a lot bigger than I thought it was.
    adidan likes this.
  11. adidan
    25 Mar 2009
    Dude, that's just too easy :lol:
    Edit: seriously though i knew it was a big unit but unless that guy is a man-child the PS5 is massive.
    The_Crapman likes this.
  12. David
    7 Apr 2009
    Maybe that guy is, like.... REALLY small?
    [edit] Homunculus, that's the word.
  13. Mister_Tad
    27 Dec 2002
    Wow. It's a big boi. Was not expecting that.
    I hope it's <440mm wide/tall.
    EDIT: And they are not messing around with that heatsink!
  14. Bloody_Pete
    11 Aug 2008
    Mister_Tad likes this.
  15. DeckerdBR
    DeckerdBR Minimodder
    9 Mar 2011
    That heat sink is something else!
    I'd be ok with the console size as long as it has good quality, quiet cooling!
    It was only the final revision of the PS4 that solved the noise and heat problems.
    Maybe PS5 will be good out of the gate in that respect?
  16. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    All the people with preview units have commented on how quietly it runs with no spinning HDD and that enormous cooler. I suspect Sony's engineers took the complaints about the PS4 and it's turbine whine to heart when designing the PS5.
    The liquid metal TIM and the standard M.2 slot are the bits that are most interesting to me. I'd love to know how they got around the issue of pump out and aging for the TIM, although looking at it it could be as simple as a square of closed cell foam around the heat spreader to seal it against the heatsink. Since nobody is going to be taking off the cooler (within normal expected uuse cases) they can go for a permanent bonded seal there.
    Still, liquid metal in a games console, badass.
  17. Yaka
    Yaka Modder
    26 Jun 2005
    one thing that's not caught anyone's eye is the dust holes for vacuuming. i am so glad they added and are pointing this out this and works as intended the ps3 and ps4 both collected an insane amount of dust inside its not until you open them that realise how much dust wool they collected
  18. Bloody_Pete
    11 Aug 2008
    More to the point, you can pop the sode off, unscrew the fan easily for cleaning!
  19. DeckerdBR
    9 Mar 2011
    Reading the above, it's seems a very thoughtfully designed console!
    I had missed the bit about it having a standard m.2 slot. Very nice given how the price of m2 drives has come down nicely.
    Lookin good so far.
  20. sandys
    sandys Multimodder
    26 Mar 2006
    Yup Gen3 M2s trade prices with SATA SSDs now, hence why I only want to buy M2 NVMe drives these days, Gen4s still command a premium, but by the time PS5 is a year or two old this should lessen, I am hoping the PS OS is sorted well enough that I can install PS4 titles to USB as I have a USB3 SATA SSD caddy and for PS4 there is negligible performance penalty using that vs an upgraded PS4 internal SSD drive (I have compared both on my PS4 pro) leaving the internal quick but small PS5 drive and M2 slot for PS5 games.
