News SoSecure smartphone-controlled SSD hits Kickstarter
Discussion in 'Article Discussion' started by Gareth Halfacree, 11 Jun 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Bluetooth access directly to the crypto IC? That's sort of like having a 'smart' bank vault door, which makes it easy to change the encryption keys pin combination by reaching through this handy window on the side...
  3. Gareth Halfacree
    4 Dec 2007
    Yes, if changing the encryption keys pin combination irrevocably destroyed the contents of the bank vault. 'Cos that's what changing the encryption key (note: not password/passphrase/PIN) would do to an encrypted hard drive: render the contents of the drive, encrypted with the old key, completely unreadable.
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Seems unnecessarily complex to me. If they would have used dram instead of nand... all that would be needed was a remote battery off command... goodbye data. Additionally it may have had a side effect of being quite a lot faster in operation.
