I have a half decent 32inch TV but the sound is quite frankly rubbish so looking to buy a sound bar. I have around £150 to spend and am looking for suggestions. I have two that seem to have reasonable reviews. Roth Audio Sub Zero. http://www.trustedreviews.com/roth-audio-sub-zero_Surround-Sound-System_review And the Yamaha YAS-101 http://uk.yamaha.com/en/products/au...-surround-systems/yas-101_black_w/?mode=model Open to suggestions as I know nothing of these things. Thanks.
Are you sure you want a sound bar and not HiFi speakers? Sound bars are like Apple products you have to sink a lot more money into them for the same quality/performance level as HiFi components. Some other options: hi-fi-system-deals £150 AV speaker packages
Sound bars are perfectly good nowadays, even for living rooms. Bit is not the place to find good advice on this stuff though, I'd suggest looking at avsforums as there are some decent reviews there.
Took your advice and decided on the Q-Acoustics Q-TV3 Soundbar which although communication was a bit iffy with the company, delivery was quick, less than a day and so far I am pleased. Good price and a perfect size as all the others I reviewed were way to wide for the space I have available. http://www.qacoustics.co.uk/qtv-3-compact-stereo-soundbar.htm
