Sound Card problems?
Discussion in 'Tech Support' started by Duste, 1 Jan 2007.
  1. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    I bought a new sound card last week, and ever since I've had problems with my sound. Every few minutes my sound will stutter where it'll jump back and forth then go on normally, as if it's lagging.
    The sound card is a Creative Sound Blaster 5.1, and as far as I know of I have the latest drivers.
  2. DougEdey
    5 Jul 2005
    Make sure you disable onboard sound from the BIOS.
  3. Duste
    1 Oct 2006
    I'll try it now!
    EDIT: I disabled it, but it's still stuttering. :(
  4. DougEdey
    5 Jul 2005
    Are you running the latest drivers for everything, and updated your BIOS?
  5. Duste
    1 Oct 2006
    As far as I know, all my drivers are up-to-date, how do I update my BIOS? o_O
  6. DougEdey
    5 Jul 2005
    Goto your motherboard manufacturers website, find your board and you'll find a BIOS download link and instructions there.
  7. Duste
    1 Oct 2006
    I'm unsure now as to if my drivers are up-to-date or not, mainly because I can't find any downloads for my specific sound card, only the Live! version of it.
  8. DougEdey
    5 Jul 2005
    Well I can't find any drivers for it, its gone past it's support life.
    Sorry, I thought you just ommitted the "Live!" tag from the name. What are the rest of your systems specs?
  9. Duste
    1 Oct 2006
    I went through some checks the other day after I got back from a LAN at my mate's joint.
    Quite simple really...First I plugged in just the bare essentials (PSU, LCD, Keyboard, Mouse, Speakers) and tried to play some songs, and they played fine. Boy was I feeling confident! So I then plugged in my Wireless USB Adapter, which I got at the same time that I got my sound card and bam, the stuttering started occurring again.
    I'm planning on doing some more tests tomorrow, such as Sound Card w/ Cat5, Onboard w/ Cat5, Onboard w/ Wireless. Could be the router, which I also got at the same time I got my sound card.
  10. DougEdey
    5 Jul 2005
    You running the latest Wireless drivers?
  11. Duste
    1 Oct 2006
    Yes, I think so, I'll check now.
    EDIT: Can't find any on Belkin's website, so I guess there's no new ones?
  12. DougEdey
    5 Jul 2005
    check all your drivers.
  13. Duste
    1 Oct 2006
    I checked what PC Wizard 2006 lists my sound card as, and it's description was "SBLive! (OEM'd for Dell?)", so I went to the Sound Blaster website and found updated drivers for that. When I tried to install them, it said I had no sound blaster hardware installed. :|
  14. DougEdey
    5 Jul 2005
    Where did you buy the card from?
  15. Krikkit
    21 Jan 2003
    This might sound strange, but if you install the original drivers, try disabling the windows Wireless Zero Connection Wizard (via services in Admin tools).
    It's a known issue with several programs that the WZC tries to reinitialize your connection every few seconds.
  16. Duste
    1 Oct 2006
    FoxComp Technology (http://foxcomp.com.au, I think) in Perth, Western Australia - I bought it from the store.
    I'll try this! Thanks.
    EDIT: Didn't work.
  17. DougEdey
    5 Jul 2005
    Not sure then I'm afraid, I was going to reccomend WZC next, as it can play havoc with belkin devices if its disabled.
  18. Duste
    1 Oct 2006
    I went to my mate's place for a little get together, and my sister borrowed the microphone while I was gone. I just realised before that there was no stuttering, and it's because the microphone was unplugged! To test my theory, I plugged my microphone back in.
    What do you know? ST-T-T-T-T-T-T-UTTER! Which is extremely weird, because I never plugged it in the first time I was testing.
    So this must mean that both the wireless adapter and the microphone were messing it up, and by disabling that Windows Zero Configuration, it fixed the adapter's problem, but the microphone was still messing up, hence why I thought it didn't work.
    Sound logical? I don't care, but it's not stuttering anymore! :D
  19. DougEdey
    5 Jul 2005
    Put the mic in, disable Microphone boost.
  20. Duste
    1 Oct 2006
    Wouldn't that make my mic softer? o_O
