A/V Sound card to match Razer Barracuda HP-1
Discussion in 'Hardware' started by Fredrics, 18 Apr 2009.
  1. Fredrics
    Fredrics Hmm...
    31 Dec 2007
    Currently i have the Razer Barracuda HP-1 headphones. However the only sound card i have is my inbuilt sound (Asus p5n-e) This means that i have 1 of the outputs for the headphones hanging out.
    Therefore i am looking for a new sound card. I am lead to believe that the Razer Barracuda AC-1 is the best match for the headphones, however is this just Razer pulling a fast one or is this really true?
    I have about £100 to spend however i would prefer to spend £60 but if it is justified then i am happy to go the full £100. However if it is judged that the best bet is to go for the Razer Barracuda AC-1 then i am sure i can find £30 somewhere *checks down the back of the sofa*
    Also i have to say that i am very against creative, but if it is head and shoulders better then... I do believe that the Asus Xonar range are the ones to be going for though?
    So recommendations please,
    Thanks in advance
  2. azrael-
    azrael- I'm special...
    18 May 2008
    The audio chip used in the AC1 is used in several other sound cards (a C-Media OxygenHD CMI8788, if I recall correctly). If memory doesn't fail me completely, the AC1 uses a special connector for directly connecting the HP1 headphones. I doubt there'll much difference in audio quality by not choosing a Razer Barracuda AC1.
  3. Fredrics
    Fredrics Hmm...
    31 Dec 2007
    Yes, there is a special connector the HD-DAI, that is the only reason i can see that there would be improved performance (it also means i can save an extra usb port)
