A/V Sound card?
Discussion in 'Hardware' started by mra123, 4 Dec 2013.
  1. mra123
    mra123 What's a Dremel?
    4 Apr 2012
    The Asus Xonar DGX 5.1 card has been reduced to £20.99 on amazon. Would this be much of an upgrade from on board audio? I currently have the latest Asus Z87 Pro motherboard, which has PCIe 3.0 slots, would this still be compatible if its 1.0?
    Always wanted a card but not sure if it would be noticeable, thanks!
  2. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    It depends on what you're using for sound - are you using headphones, speakers, earphones, SPDIF, optical etc?
    The DG has a headphone amp, and so will be nice if you've got a big pair of studio headphones, but of less use with earphones or speakers. The quality will be better than nearly any on-board, including your motherboard.
    PCIe 3.0 is backwards compatible all the way, so a PCIe 1.0 add-in board will work in a PCIe 3.0 slot.
  3. mra123
    4 Apr 2012
    Currently a mid range pair of stereo gaming headphones and thinking of possibly grading to 5.1 speakers from current 2.1 Logitech set. More importantly I have the HAF X case so I want to fill it up a bit more as it looks rather empty!
  4. Marvin-HHGTTG
    10 Oct 2010
    In which case, it's certainly worth a go, they've got virtual surround for your stereo headphones which is rather good in FPS and such for positional audio (better than 5.1 or 7.1 headphones) as well, and the amp and signature will be better than onboard.
  5. mra123
    4 Apr 2012
    Sold!
