A/V Sound not working. HELP!
Discussion in 'Hardware' started by ek-hat, 31 Dec 2005.
  1. ek-hat
    ek-hat What's a Dremel?
    12 Dec 2005
    System specs:
    AMD Sempron 2800+ 90nm skt 754 (using reference cooler)
    ASUS K8U-X motherboard
    Kingston 512Mb PC3200 RAM
    nVidia AGP 8.0 slot GeForce 64Mb MX440 (recognised as MX4000 by OS)
    30Gb hard drive
    Cool Technology 350W PSU
    32x CD ReWriter drive
    Windows XP Professional
    I'm using my onboard codec and audio connectors to connect up my Labtec Pulse 385 2.1 surround sound speakers. But for some odd reason, Windows XP is not recognising any sound device and I can't get Volume Control to run, but when I turn on the speakers, I can hear vibration going through the speakers which means it must be working but my operating system (Windows XP) is not recognising any sound device whatsoever. I think the problem could have something to do with the onboard sound codec or mini jack connectors. I've got AC'97, which is the audio codec of my chipset enabled in the BIOS.
    So what seems to be the problem? Any ideas, anyone? Please help :worried:.
  2. cerberus
    cerberus What's a Dremel?
    23 Sep 2003
    I know this sounds daft but have you installed the sound drivers off your motherboard disk, I had the same problem until I realised that XP doesn't install them automatically.
  3. ek-hat
    12 Dec 2005
    Wow, now I feel like an idiot lol. I thought Windows XP would have generic drivers for the sound... wouldn't they?
  4. cerberus
    23 Sep 2003
    Not always, when ever I reinstall xp on mine or the missus pc I've always got to install the sound drivers seperatley, where both using onboard sound at the moment.
  5. ek-hat
    12 Dec 2005
    OK thanks for your help Cerberus. I've installed the drivers for the onboard sound device; it's working fine and I'm able to adjust all the settings.
    BUT, there's no sound coming from the speakers. I've checked to see if any of the volumes are muted, but they weren't.
    Could anyone tell me why this is :(?
  6. cerberus
    23 Sep 2003
    Glad I could help
  7. ek-hat
    12 Dec 2005
    :) Do you have any ideas as to why there's no sound coming from the speakers though?
  8. ek-hat
    12 Dec 2005
    UPDATE: Speakers working now, thanks again Cerberus :).
  9. cerberus
    23 Sep 2003
    Your welcome
