Electronics Sound Volume Display
Discussion in 'Modding' started by DickH, 14 Oct 2004.
  1. DickH
    DickH What's a Dremel?
    6 Jun 2004
    For my project, I want to have two lines of LEDs display the volume of the left/right speakers. I got as far as figuring out the LM3914, and figured I would use one for each side, but what do I need to do to get the volume to the LM3914, without doing anything to the quality of the sound. If It matters, This will be for front headphone jack, and I plan on having the volume controll be on the faceplate.
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    You'd be better with the log-scaled LM3915, get the datasheet & see fig.1 in the Application Hints for a high-impedance input & rectifier circuit.
  3. theshadow27
    theshadow27 What's a Dremel?
    23 Sep 2004
    this kit is realy nice, if you want to build it yourself i have a circut somewhere... ill try to dig it up when i get home
  4. DickH
    6 Jun 2004
    So, I looked up the lm3915 and came across this
    So will I have to just make two of those, one for each side. The output will be a pair of headphones 95% of the time, will that cause any problems? or will I need a little amp or something for the lm3915
  5. theshadow27
    23 Sep 2004
    the headphone amp should be perfect... most headphones are 8 ohms, some older ones are 32
  6. DickH
    6 Jun 2004
    any suggestions for the amp?
  7. theshadow27
    23 Sep 2004
    wait your not using the amp in the mobo?
  8. DickH
    6 Jun 2004
    I would like a volume knob, but I would be ok using the normal signal from the sound card.
  9. '99
    '99 What's a Dremel?
    5 Jan 2004
    Are you planing to implement a switch for headphone <-> Speaker? I'm looking for one, and one that is'nt using a mechanical switch but some sort of flip-flop.
    Sry. for using you're thread :blush: but since it fit's the subject :thumb:
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Work out what's happening here. The two resistors R1=390, R2=2k7, on pin 7 turn the LM3915 into a 10V FSD meter. The ingoing R1=18k, R2=10k, divide the speaker voltage by around 3 for the 8R speaker case. So 30V to the speaker lights the full bargraph. That's around 80W RMS from the amplifier. Fair enough for a power amp.
    But you're going to have to change some component values to cope with the soundcard output, or that from a small headphone amp. ;)
  11. DickH
    6 Jun 2004
    yeah, thats my concearn
    "The output will be a pair of headphones 95% of the time, will that cause any problems? or will I need a little amp or something"
    got any Ideas?
