A/V soundbar over speakers ?
Discussion in 'Hardware' started by stormbringer500, 13 Apr 2015.
  1. stormbringer500
    stormbringer500 What's a Dremel?
    6 Jan 2010
    I am thinking i may take the plunge, just wondering how long the power cord is and how long the cable going to PC is, as then I can determine where I am going to put them.
  2. ShakeyJake
    ShakeyJake My name is actually 'Jack'.
    5 May 2009
    Microlab 7C here and loving it, can't recommend enough.
  3. stormbringer500
    6 Jan 2010
  4. ak_2020
    ak_2020 Minimodder
    22 Nov 2010
  5. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
  6. stormbringer500
    6 Jan 2010
    Well I received them yesterday unpacked them and man they are BIG!! so I plugged them in and played some Halestorm to see how they held up and really superb speakers, but unfortunately I had to return them as where I wanted to put them they were two large, I did come up with alternative space but that failed as well.
    Looks like I will stick with my Logitech Z2300's for now and look for a alternative sometime.
  7. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
  8. OmegaStalker
    OmegaStalker What's a Dremel?
    8 Jul 2013
    If you do go down the sound bar route the JBL SB400 are excellent option might be able to pick one of the bay for your budget.
  9. stormbringer500
    6 Jan 2010
  10. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    I've just picked up the Solo9Cs because the 7C's aren't available. They're MASSIVE!
    Can someone please call my other half and explain my purchase? I blamed this thread.
  11. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
  12. Mister_Tad
    27 Dec 2002
    Your problem was using the 7Cs as a reference point. What you should have done is explained before they turned up that because you love her, you decided not to buy the 12Cs (which are twice as large and twice as expensive, obviously) and instead compromised on the 9Cs.
    She doesn't need to know that the 12Cs aren't a thing.
  13. jinq-sea
    15 Oct 2012
    I can do that for you. No worries. She'll not believe anything I say though, because she knows that I am worse than you.
  14. sandys
    sandys Multimodder
    26 Mar 2006
    I have been using a sound bar, got fed up of the cabling issues with the number of machines connected particularly my consoles so pump it all through this via HDMI switch.
    http://www.trustedreviews.com/panasonic-sc-hte80-review
    It's not perfect but it's compact cheap (150) and I can stream music/podcasts to it via Bluetooth too which is nice.
    Probably not for the audiophiles but it does me.
  15. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    Might make me look good by comparison :idea:
  16. Chunkers
    Chunkers Meat Popsicle
    24 Aug 2010
    I have a Yamaha DSP-2200 sound-bar which sounds great and has given me many years of good service but it was a lot more than £150.
    To get an improvement in sound over your current speakers I think you are goig to have to do some serious homework, a £150 soundbar is probably going to have a few compromises in its construction to get down to the price.
    I think the advice elsewhere in this thread is sound but maybe save up for a few more months and spend a little more?
    Chunks
