Build Advice Soundcard and 5.1 speakers
Discussion in 'Hardware' started by Darksky, 31 Dec 2011.
  1. Darksky
    Darksky What's a Dremel?
    31 May 2010
    Hi all
    Can someone please advise me? i'm looking to buy a new soundcard and 5.1 surrond speaker system for my desktop computer, iv'e been looking but cannot come to any conclusion as to whats best to buy. My motherboard is a P8p67 pro, some advise would be a great help.
  2. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Well Sound card wise a Asus sonar is a good choice DG or DX2.
    I do not believe in 5.1 systems under 300-400 pounds with real HiFi speakers. I find that a good set of Bookshelf speakers and amp will give much better sound quality.
    I would suggest a set of Tanoy V1 Speakers + Best amp in your budget.
    http://www.richersounds.com/product/bookshelf-speakers/tannoy/mercury-v1/tann-mercury-v1-oak
    This is my amp:
    http://www.richersounds.com/product/amplifiers-receivers/denon/pma510ae/deno-pma510
    If you insist on a "5.1 system" then don't do below whats here:
    http://www.richersounds.com/information/home-cinemasystems
    I would suggest system 2 minus the bluray player.
  3. Darksky
    31 May 2010
    Thanks for the reply i'll take a look.
  4. Guest-16
    Guest-16 Guest
    We've got a new Xonar coming at CES
  5. Guest-44432
    Guest-44432 Guest
    @Bindi: -Why 'Don't' the ROG boards come with the Xonar built into it? As now, I'm stuck using pants onboard sound, which sounds so flat, and probably sounds worst than Argos best Alba Hifi?...
  6. jizwizard
    jizwizard Modder
    24 Dec 2010
    Nothing wrong with alba lol could be worse could be pye
  7. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    They used to, I know the RE did.
  8. bagman
    bagman Minimodder
    18 Apr 2009
    Better than Xonar STX.
  9. Guest-16
    Guest-16 Guest
    Muaahahahanomonomnomooohyesmaybe.
  10. Darksky
    31 May 2010
    Aye iv'e had enough with onboard sound, I want a 5.1 system that I can set up in the small room that I have my desktop in.
