Hey good work there! Do u put the heat sinks on the out side oof the case when the PSU is installed? PS, can a moderator put a 56k warning in the title of the thread, the pictures r huge!
arent those Heatsinks gonna be live (i think ). and that took agood few secconds to load on 1.5mb cable so 56k warning deffo needed. nice mod nice pics
I don't use the psu in my case. It's outside of the case, but the heatsinks is that place where before is the fan. So heatsinks is bottom of the psu, top of the processor.. Those heatsinks are from the old 233MHz Pentium II (Slot 1), ~12x6cm.. (I know, my bad english ) And I forget to put 56k warning on topic, but i resize pictures later..
Dont worry, some off the ppl round here (who apparently speak english) speak worse englich than u. Im refering to my loacal area, not the forums b4 ppl flame me 4 that!
don't worry about the english, to use any computer related boards these days you have to be able to read engrish fairly well
If you look carefully, there are thermal pads between the chips and the sink, so everything will be just fine I must admit, its easy to forget to do things like that tho. Just built a fanbus for my system (five channels) and packed the circuit in nice and tight. However, the heatsinks on the ICs were all touching (plus id forgotten to put isolating thermal pads between the ICs and the heatsinks) and the end result was a massive short that put a huge surge of heat thru the 'sinks and huge blisters on my fingers. Nothing broke tho, funnily enough. Great idea with the PSU - do those huge heatsinks run cool enough?
56k warning my be needed im not sure my 512k loaded them straight away no loading needed, so dude your 1.5 must be going slow or something, anyway looks good, messy but good
Thats a good idea for the PSU... warrmr your cable really is slow if i took more than a second to load them pics, im on a satellite connection and it only took 2 seconds...
I resize pictures from 1024x768 to 640x480, so pics come fast now . The heatsinks run little warm, about 40-50c. It's hard to say, because i don't have any temperature-meter..
That is better if it make like one heatsink to one IC.. and separate every heatsink something like plastic, or something that don't lead electric. And leave the thermal pads out.. So thermal-lead is better..
