Windows Sounds gone mad BF2
Discussion in 'Gaming' started by Pie_uk, 26 Sep 2005.
  1. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    :sigh: basically i turned on bf2, it came up and was asking me if i wanted to play single player or online ( as if i was new to the game ) so i searched for my user account and hey it worked!!?
    so i load up a game as soon as the game loaded all i can hear is all the sounds from all over map as if i was really close to them :confused: :duh: :miffed:
    so i could hear tanks cards guns even tho i am on a rmote part of the map, so i set the sound to medium and software , this sorts it out but i get a constant crackling noise, so i set it to hardware this stops the crackiling noise but then i hear everything at the same time it gives you a bleeding head ache just what the hell is going on, it was fine yesterday
    any help will be great
  2. malccy72
    malccy72 Minimodder
    9 Jan 2005
    Don't want to sound predictable but maybe update sound drivers/other drivers.
  3. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Do you by any chance run a Soundblaster Audigy?
    Every member in my clan who had one of those cards had it happen and I dont think anyone found a fix.
    Possibly dissable EAX, set sounds to medium + hardware.
    Also as already said, drivers :)
  4. Pie_uk
    6 Apr 2005
    hey thanks for info, i have latest drivers i think im using on board realtec ac97 sound or something? no i do not have a sound blaster :)
    could i re install the game? or would that upset my rank etc?
    i cant belive its doing this, it was fine yesterday!!!! please continue to help :D
  5. neillyb
    neillyb What's a Dremel?
    7 Jan 2005
    Reinstalling the game will not affect your rank because it's stored on EA's servers.
  6. Pie_uk
    6 Apr 2005
    ok i have fixed the game by check disking the hard drive, now about the ranking system im currently lance corpral it seems as tho its been stuck on a certain bit of the upgrade bar, why isnt it moving ? what do i have to do to get up to next rank level/ obv i have been playing the game but is there any things in perticular that i need to do such as play the sniper for a certain amount of time?
  7. SECRETCOMMANDO
    SECRETCOMMANDO What's a Dremel?
    18 Aug 2003
    Not to reach a new rank there aren't. Just be patient, it takes a lot of points to reach corporal, you need about 10,000, from the 1000 you need for Lance Corporal - big difference.
    Oh, and obviously only play on ranked servers. ;)
  8. Pie_uk
    6 Apr 2005
    ok wow that could take ages!!!
    what do the bars mean next to the guns here [​IMG]
  9. Lazy
    Lazy Meow?
    13 Nov 2001
    isn't it how fast you can sprint?
  10. Pie_uk
    6 Apr 2005
    yer i think so cheers :)
