I dont think my smartcard reader is working. Is it made for your mobile phone sim card??? I try but it just says it cant find anything.....have i set it up right? I WANT MY CARD READER!!!!
On mine, I open the supplied reader programme first, stick the sim chip in the holder card, then press the read card button. This all works fine if you have installed the driver from the cd. It doesn't do this automatically, you have to select it from the cd menu or explorer! By the way, the sim chip should face down in the reader (my first inclination was to put it in upwards) so check that!
