Windows Sp1a windows xp problems
Discussion in 'Software' started by Sc0rian, 4 Apr 2004.
  1. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    sooo
    I re-install windows.... and got this error
    !!! What can I do??? Iv tired to close all apps.
  2. Sc0rian
    23 Feb 2003
    bump :confused: :worried:
  3. Mister_Tad
    27 Dec 2002
    try killing loads of processed and services as well mebbe? :confused:
    or maybe it would work better if your sig wasnt half a page long :D :thumb:
  4. ajack
    ajack rox
    17 Apr 2003
    That is the mother of all sigs tbh
  5. Sc0rian
    23 Feb 2003
    yeh i have tried that, and done it in safe mode
    Yes the sig, gonna resize when I get around to it
  6. jgrade
    jgrade What's a Dremel?
    2 Mar 2004
    Here is an article from Microsoft. In short it says that your error could be caused by faulty memory or problems in the mass storage controller subsystem (I.E. LARGE HDD).
    Also try this article
    The other issue I saw while searching was problems with CD-RW's Check with the manufacturer to make sure you have the latest drivers.
    Hope this helps.
  7. Thunder_return
    Thunder_return What's a Dremel?
    8 Jun 2003
    Mostly a cdrw problem, because it says "atapi" in the end of the message.
    Could be Deamon tools that uses the cd at the same time as
    the install.exe?
  8. Sc0rian
    23 Feb 2003
    i ended up renaming the file and it installed....then windows made the file again when i rebooted. Seem to of done the trick.
