Modding Spare LEDs
Discussion in 'Modding' started by hjertis, 25 Jun 2004.
  1. hjertis
    hjertis What's a Dremel?
    10 May 2004
    I have at least 3 spare blue LEDs and about 10 yellow and 15-20 green ones. And I have no ****ing clue what to do with them. Could use some suggestions. The chassi I have is a Aopen. Pic included a bit down.
    Does anyone have some cool and not expensive stuff you could use some LEDs for?
    the chassi
  2. robotguy9000
    robotguy9000 What's a Dremel?
    3 Jun 2004
    change the power leds
    duh!
    or you could also :search:
  3. hjertis
    10 May 2004
    think i just might do that :) change the power and hdd LED to blue ones. :) that should be nice i think.
    and i've already looked at a lot of cases here, but haven't found some cool stuff to do with a lot of LEDs..
  4. Bentos
    Bentos What's a Dremel?
    12 Feb 2002
    VU meter, get a kit or the schematics and build yourself one.
    would look cool in the front of the case
  5. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    Light the underside of that case and connect it to the hardrive through an optoisolator and transistor so each time the hardrive is accesssed, it would blink.
  6. evilstriker
    evilstriker What's a Dremel?
    29 May 2004
    you can also change your mouse led(if you have optical) also you can change your keyboard leds. you can also trie a knight rider led cuircuit (one that goes up and them depending on cpu load time
  7. hjertis
    10 May 2004
    you all have great ideas :D i will try to change the mouse LED to a blue one. That red one is a bit annoying.. :/ I have lighted the underside of the front. but i don't like the idea of making them flash. :/ That Knight Rider stuff and the VU stuff sounds cool. Will search for some schematics and build me one. (have acces to a lot of free stuff since one of my friends work at a electronic company that builds stearing systems for timbering machines :) )
    And again. Thanks for all the cool inspiration! :D
  8. robotguy9000
    3 Jun 2004
    are there any disadvantages to changing your mouse led?
  9. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    You might break your mouse
  10. robotguy9000
    3 Jun 2004
    it doesnt affect performance?
  11. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    As long as the LED is bright enough, there shouldnt be any performance hit. A good guide is: it has to be above 1000mcd to work, generally, and it idoesnt seem to work with a colored lens.
  12. robotguy9000
    3 Jun 2004
    hmmm... ok thanks. still wouldnt want to do that on an expensive mouse, though...
  13. lamcdonald
    lamcdonald What's a Dremel?
    1 Mar 2004
    I've modded half a dozen mice, and the biggest problem I found is the quality of the circuit boards :/ On many of them, the tracks lift when you're desoldering them for the first time!
    I have used just about every LED colour there is :D And they all work, although some are better than others.
    Best:
    Infra Red
    Good:
    Red
    White
    Blue
    Green
    Pink
    Not so good:
    Ultra Violet
    Yellow
  14. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    I found when I changed my Logitech Mouseman Dual Optical from red to white, it was fine on a cloth pad, but when I switched to a RatPadz, performance really took a hit. I switched to 8cd (from I think 4cd) and it works perfectly now.
  15. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    Infrared works the best? That's really neat, I'll try that some time.
  16. Firehed
    15 Feb 2004
    Well naturally... I'm pretty sure that's what kinda light the sensor pics up. Kinda why a blue cathode makes UV stuff glow a little bit... the red is close enough to IR. and it won't keep you up at night with it blinking all over the place since IR is invisible to the human eye.
    good to know about 1000mcd... I didn't wanna have to stack LEDs. Maybe I'll have some fun soon. A 12000MCD ultrarbright white LED may be in my mouses future! And the decorative one in the back would definately need to change.
    Heh, change it to one of those rotating RGB ones :dremel: Don't forget a resistor though... I think I killed several LEDs that way not knowing I had a 3v LED and a 5v source with the mouse (or something to that extent)
  17. hjertis
    10 May 2004
    isn't there already a resistor in the mouse? or do they have some special 5V LEDs? I think my blue LEDs is at 2.75V. I may wanna check that out and do some calculating to find a nice resistor to fit my needs. I sure hope here are some store around that sell loose resistors. It's kinda useless to order 1 resistor... :p
  18. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    I put one of those white LEDs in my cordless. It works, and looks nice. The 12000 MCD led "prefers" a higher voltage than most leds on cordless mice. So it's only slightly brighter than the red one that came with it.
  19. phil si
    phil si What's a Dremel?
    15 Aug 2003
    hmmm could rig something up with some new Blue/Red Leds... alternating style :D red on idle, blue on movement would be sweet, hard to implement though, knowing nothing about optical mices :D :idea:
  20. Zogthetroll
    Zogthetroll What's a Dremel?
    5 Feb 2004
    Here is a nice VU meter circuit diagram. The only thing to note is that it's for mono (single channel) sound, so for it to work for stereo you need to make two of these and hook the left and right audio signal up to them seperately. check the main pc in my sig to see the end result.
