Electronics Spare PSU question
Discussion in 'Modding' started by Alwayz Dead, 12 Mar 2002.
  1. Alwayz Dead
    Alwayz Dead What's a Dremel?
    5 Mar 2002
    I have a spare PSU that I want to use as a test rig for the odd thing or two but don’t want to connect it to a Mobo. Do any of you guyz know how to rig this thing so I can get it to fire up. Is it a matter of just knowing the correct pins on the mobo socket or shall I just close the door quietly on the way out!!!!!
  2. eaterofpies
    eaterofpies What's a Dremel?
    12 Feb 2002
    run a search for dual psu on mod search i know there is a guide that shows how to power 1 up but my internet is playing up (GRRRR AOL)
  3. Alwayz Dead
    5 Mar 2002
    Got it.
    Thanks mate:)
  4. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    the main green or gray one(main powere switch), and connect that using a paper clip to any of the black(ground) ones....
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    You'll also need a load of about 1A on the 5v line to get the thing working, Antec make a test device reviewed here that has a 5R4 (?) 25W resistor, a led to show its on, and a link from green wire to black.
    The 25W resistor's overkill, a 4R7 or 5R6 7W or 10W would be fine if air-cooled & not wrapped in insulation.
  6. Alwayz Dead
    5 Mar 2002
    Great stuff
    Thanks people:)
