News Sparkle coats GPU coolers with diamond-like carbon
Discussion in 'Article Discussion' started by CardJoe, 17 Feb 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    that's just bullocks...
  3. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    A few days ago I read a story about a "carbon like material" that was 58% times stronger then diamond. So this can be truthful.
  4. Psytek
    Psytek What's a Dremel?
    23 Dec 2008
    I don't doubt that this compound has higher thermal conductivity then copper... but will it ever be affordable enough. Making usual carbon compounds like these, carbon fibre, nanotubes and graphene all suffer from limited growth because of their prohibitive manufacturing costs.
    A solid silver heat sink would be better than copper, but it doesn't matter because its too expensive.
  5. Psytek
    23 Dec 2008
    that should say *unusual carbon compounds
  6. Kúsař
    Kúsař regular bit-tech reader
    23 Apr 2008
    So basicaly - it transforms heat to light? I love physics :D
  7. Krikkit
    21 Jan 2003
    No, the transfer is from phonons, not photons. They're different things, although they are rooted in the same mathematical description from statistical mechanics. A phonon is best though of (as long as you don't want to start bustin' some science on it) as the vibration of a molecule within a lattice vibrating. The "connection" with the other lattice sites allows for a fast transfer of vibration, much faster than the poor old conduction electrons.
    This sounds like an interesting material and if it can be made cheaply enough, a great alternative to an all-copper heatsink. After all, carbon is pretty damn abundant, whereas copper will inevitably run out sooner or later.
  8. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    metals prices have started to go up... this is a logical step in the right direction.
  9. Jack_Pepsi
    Jack_Pepsi Clan BeeR Founder
    24 Apr 2006
    Paying through the teeth for 5°C which isn't set in stone... pfft!
  10. ChielScape
    ChielScape What's a Dremel?
    17 Feb 2009
    "This differs from heat conduction via a standard metal heatsink, which relies on the movement of electrons in the metal."
    Electrons? What? When did the Laws of Nature change without anyone telling me?
    heat is the energy that particles posses by vibrating, passing that vibration onto other particles is how heat transfers trough solids and fluids. (it can pass trough a vaccuum and transparent materials as radiation)
    I dont know if Ben just copied it or wrote this himself, so i wont automatically direct this at him, but the guy who came up with that is a class A idiot.
  11. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Meh. I take 30° off my cards simply by putting them on water. :p
    In all seriousness, I'll believe it when I see the proof.
  12. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    so is this like that IC 7 Diamond thermal compound but just even more refined?
  13. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    no it is some carbon fooled into thinking it is diamond... and it acts like it too, so it (should) conduct heat better
  14. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I'm going to need proof of it first before even thinking of buying it
  15. Horizon
    Horizon Dremel Worthy
    30 May 2008
    why don't they make heatsink out of the stuff they used to wildfireproof a house from smash lab, it was amazing it resembled plexi but it doesn't even burn and transfers heat almost instantly, they put it under a torch for a few minutes and was able to be handled with bare hands almost immediately. they need to make heatsinks out of that stuff.
  16. desertstalker
    desertstalker What's a Dremel?
    7 Feb 2004
    That "stuff" is an insulator, it work very poorly as a heatsink. The reason you could handle it straight away is because it doesn't absorb any heat.
  17. sui_winbolo
    sui_winbolo Giraffe_City
    25 Sep 2004
    This sounds expensive.
Tags: Add Tags
