Electronics SPDT wiring
Discussion in 'Modding' started by bixie_62, 8 Jun 2005.
  1. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    hey all
    have a single pole double throw switch in my hands, rated at 3A, 125Vac.
    it has 6pins on the rear labelled one to six.
    how would i wire this to switch a fan between 7 and 12v?a diagram would be VERY much appreciated.
    thank you very much!
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    This came up all of 2 days ago. :search:
    By you. Please read replies to your own posts. :rolleyes:
  3. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    i did read the replies! the problem was that no-one replied answering my question! sorry.
    anyway..
    i seem to have it figured out.
    pins 1 and 2 are joined together and are the + for com a
    the centre 2 are joined together and are common ground
    last 2 pins are joined together and are the + for com b.
    how do i now wire this to switch between 7v and 12v?
    thank you.
  4. c.cam108
    c.cam108 Minimodder
    14 Feb 2004
    You're lucky I have a spare 2 minutes. Here you are:
    It's not difficult. At the bottom is your molex. Yellow is 12v, Black is 0v and red is 5v. 12v goes straight to the fan positive as normal. The fan negative goes to the center pole of the switch. The two outer poles each go to 5v and 0v.
    _C
  5. g0th
    g0th What's a Dremel?
    12 Apr 2005
    :sigh: :eyebrow: :grr: :rolleyes:
  6. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    that didnt make any sense to me.sorry.
    thanks double c, it works!!
    ok, i was talking to my dt teacher, who also did a bit of electronics, now they mite be able to order from RS for me, using the school tax code or whatever it is as they use RS and RS only deal with trade.
    i was thinking of perhaps constructing a fan controller using a pot, and i saw one on cpemma's website that uses a transistor.
    does anyone have any links or guides as to how to make one of these?
    my electronics teacher's really interested now! and she wants to make one too, so i aint complaining!
    thanx
