Speakers and Tv for live 8
Discussion in 'General' started by neonplanet40, 2 Jul 2005.
  1. neonplanet40
    neonplanet40 What's a Dremel?
    3 Mar 2003
    Hi everyone. Watching live 8 now and want to liven up my expierience! Ive got logitech z 5500's and i wanna hook them up to the tv. the only way it seems to work is through the headphones jack and it sounds crap. cant turn it up much or it cracks. anyone got any other ideas on how i can maybe do something to hook them up a different way or somthing?
    Neo
  2. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    If you have a dvd player stick em through there!
    <A88>
  3. neonplanet40
    3 Mar 2003
    how can i get it through dvd player to play whats on tv?
    Neo
  4. <A88>
    10 Jan 2004
    I honestly have no idea sorry, I just assume it's possible :\
    <A88>
  5. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    The only way would be to go through a vcr. Just use the vcr to tune the channels, not the tv. Thats about the only way
  6. Lowsidex2
    Lowsidex2 Minimodder
    29 Sep 2003
    Does the TV have any RCA audio out plugs? If so and they just aren't working, try the TV's setup menu, you might have to turn them on.
  7. shroom
    shroom What's a Dremel?
    6 Aug 2003
    Ive got a digital cable box that I plug my 5.1s into. Its basically a big beefy tv tuner box from the cable company.
    Pretty much the way it works is if there is a box between your tv and the cable connection, you would plug into that. Thats why it works with a vcr.
    As for it crackling on the headset port, try changing the volume on not just the tv but the speakers also. Sometimes youll get better results turning your tv nearly all the way down and then using the volume control on the speakers, or even vice versa.
  8. neonplanet40
    3 Mar 2003
    Thanx dude i turned tv sound down and speaker upa dn theya re much clearer! Excellent concert! thanx for help guys!
    Neo
