Build Advice Spec me a build for £750
Discussion in 'Hardware' started by Nealieboyee, 8 Jun 2018.
  1. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Greetings
    What would be the best gaming build I could get for £745 including a monitor (24 inch 1080p)? Playing modern titles but not looking for ultra settings.
    Something future proof with an SSD would be good. Possible AM4 as not looking to upgrade CPU and Mobo for a couple of years at least.
    Matx is preferred.
    Thanks guys
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    Ohhhhhhh the PC Part Picker game! My favourite!
    How about this? https://uk.pcpartpicker.com/list/7NM4pG
    It's a little over the budget but I'm gonna say it's pretty good imho.
    Note, you'll have to check for RAM compatibility with the board.
  3. Vault-Tec
    30 Aug 2015
  4. acemodder
    acemodder Official Antec Rep
    13 Apr 2013
    For the case, I urge you try an Antec P6 chassis, if you are looking for mATX.
    This is a photo taken from a forums user of another IT hardware forum in the UK.
    I quote his post...
  5. Guest-56605
    Guest-56605 Guest
    Neal, I have one of THESE surplus to requirements if a 29" superwide is preferable to a 24".
    Direct Imgur pic link for said monitor
    As it's you fella I'm sure we could work something out, it has zero dead pixels, all the bits and is boxed.
  6. Nealieboyee
    14 Aug 2009
    Thanks for the replies guys. This build isn't for me, but my friend seems happy with it.
    @23RO_UK Thanks for the offer mate, but I've JUST bought a used 40inch TV that I'm using as a monitor.
    Guest-56605 likes this.
  7. Guest-56605
    Guest-56605 Guest
    No worries mate :thumb:
